Question about Whirlpool AWZ412 Front Load Washer
Hi my washing machine starts but afta 5-10 minutes it keeps tellin me to clean pump... how do i do that and where is the pump?
  • 569 Answers
Try cleaning the filter first. The filter is behind a flap on the lower part of the front panel of the machine. The flap is normally opened by pushing at one side - then unscrew the cap that is behind the flap and withdraw the filter. Clean it thoroughly and replace.
If this does not work you will need to remove and clean the pump itself, which is accessed from beneath the machine, but this is a more major job.
Posted on Jan 04, 2011
Testimonial: "thank u"
When i start it it idles for 20 sec then dies it will start back up then dies again ?
sounds like a fuel problem Mike. be sure fuel lines are in good shape. fuel filter not plugged air filter is clean. check to see if there is any dirt or water in the fuel bowl. may need to take the carburetor apart and clean real good.
Oct 02, 2016 | Garden
Hi there, the drain pump keeps running and nothing else happens on my dishwasher. Any thoughts?
The make and model would be nice to know. Most of the new machines start with the drain pump initialization to begin a diagnostic self test. IF it is sticking in this phase, then the sensor that tells the machine is full has a problem or the control board is bad. To reset the machine, unplug it or shut off the breaker for a minute.
Oct 04, 2015 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Apr 18, 2011 | Hotpoint Washing Machines
Hi my whirlpool washing machine keeps stopping with the clean pump light on. I have cleaned the filter at the front and removed the pump underneath to clean it and to make sure there was no blockage. It...
Hello
There should be a clean mode.You need to get some E A high effic cleaner.And run the machine in Deep cleaning mode.
This will clean the machine and drain.
Apr 04, 2011 | Washing Machines
Have a front loading Whirlpool washing machine.. It keeps flashing F21 what does this mean??
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Washing Machines
LG WT-R852 washing cycle never finish. It will keep repeating cycle until OE error sign shows up.
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Washing Machines
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Outer door dyson washing m/c
try turning screw under detergent tray?
Sep 05, 2009 | Dyson Memory CRO1 Front Load Washer
Washing machine not draining water during washes
hi..The problem most probably is your pump is not working
or the hose that the water drains out is blocked.
check it out..
thank u..
kindly rate my response..
May 08, 2009 | Washing Machines
Whirlpool AWZ412 Front Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
