Question about GE 31GT740 31" TV
GE 31GT740 TV problem
My brother gave me his GE Guide Plus Gemstar TV. We don't have a clue what Guide Plus is and can't get the tv past the set up screen. Is there a way to turn off the guide plus system and just use it as a regular tv? Is the remote the problem?
  • 2 more comments
  • mbaldone Oct 22, 2008
    I have the same problem, but I do not have the remote
  • charloddy66 Feb 10, 2009
    no signal
  • Anonymous Feb 14, 2009
    MY TV WILL WORK FINE WITH A REMOTE TUNER BUT IF I PLUG THE TV STAIGHT TO THE CABLE I GET CHAINEL 3 ONLY, I TRIED EVERYTHING WHAT AM I MISSING ? HELP
  • kag22 Mar 28, 2009
    whenever I turn on the tv, the guideplus screen pops up. To turn it off, I hit the "guide" button on the remote. I would like to disable it from even popping up but haven't figured out how to do that yet. I have directv and it's annoying having to use 2 controllers every time we turn on the tv.
Hit the clear button on the remote and it will clear the guide plus off the screen
Posted on Sep 28, 2008
Proscan universal remote control Codes List
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Dec 26, 2013 | GE Original Crk17tb1 Guide Plus Gemstar Tv...
Gemstar Guide Plus TV Guide popup
1) Reset the code go www. fitness.manualsonline. com or www. remotecodelist.com and downlod for free
2) Try again and proof.
3) If the problem persist you must go to the repair shop TV for fix it
God bless you
Jun 14, 2012 | Directv RC32 Remote Control
GE GEMSTAR WONT POWER ON
Older set and prone to bad High Voltage Transformers and other problems--may or may not be worth repair---if won't come on anything from a fuse to a major part and some parts just may not be available any more for this model.
May 23, 2012 | GE 31GT740 31" TV
I have a GE guide+ gemstar model 31GT740 i cant get cable reception the cable is fine as i hooked them to another tv and it worked fine i did auto channel and it scanned all channels when it was done it...
your have problem with the system IC's which store the channel and all the control in the TV or it can be remedy by soldering the pin of the IC's if the problem persist well your have to replace that system.
Sep 07, 2011 | GE 31GT740 31" TV
I have a 31GT740. Need g link and users manual. Where would I find a g link cable and users manual for it. I'm not really sure how old this set is. Any help would be apprieciated.?
1.)This set should have the date on the back of it; it should be a a 2003 model.
2.) You may be able to find a user manual by google on the internet.
3.) The part number for the G link is:
238293 and it is no longer available(about a 16 dollar item)--you may be able to find someone on Ebay who has it----these sets with the guide plus never worked very well.
4.) I do this here for free so if this information helps you--take a minute and give me a vote here.
REGARDS: SD TECH......
Sep 07, 2009 | GE 32GT740 32" TV
Our Guide Plus shows no listings. We have gone
This is For Guide Plus that comes with ATI TV Tuners
I got this in an e-mail from Macrovision and IT WORKS!!!
I deleted the files they said, and got a new error message, so I reinstalled Guide plus, left out that step, and GUIDE PLUS IS BACK!!
Please try belows instructions to see if that helps. Please back up any data and registry before going forward. We take no responsibility for any wrong doing. Please follow instructions carefully.
1. Delete all files in these directories:
C:\Program Files\Gemstar\GUIDE PLUS+(TM)\ATI\download
C:\Program Files\Gemstar\GUIDE PLUS+(TM)\ATI\panelad
2. Go to the computer's registry:
Go to HKEY_LOCAL_MACHINE\SOFTWARE\GEMSTAR\ETV\URL
Find the strings:
"1"
http://www.gemstarguide.com/gdndl/gdnget.asp
"2" http://www.gemstarnet.com/gtidl/gdnget.asp
"URL" http://www.gemstarguide.com/gdndl/gdnget.asp
Change string "1" to
http://144.198.100.134/gtidl/gdnget2.asp
string "2" can be left alone
string "URL" SHOULD be
Aug 18, 2009 | RCA Televison & Video
I have a 27'' GE stero mointorguideplus will not show tv listings
it sound like your gemstar is bad whicth the panel bad.
Aug 12, 2009 | Televison & Video
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
Guide Plus issue...
Yep ... just figured this out myself today. When the Guide screen is up, navigate thru the options to Setup. Then select Review Options. You then get to a screen that gives you the option to turn of the system auto display. Good luck!
Aug 15, 2007 | GE 31GT740 31" TV
GE 31GT740 31" TV Logo
595 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
