Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How do i conect this mixer to the laptop - Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
  • 3,400 Answers
You need to by cable mini tip to XLR or to 1/4 inch TRS connector. Any guitar center can hook you up w/right cable it's a simple thing.
Posted on Jan 04, 2011
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Yes i have a mackie onyx24.2 im trying to conect some compressors into the chanel insets. but when i plug it in it shuts the sound out... what's the problem?
Sounds like you've got the compressors etc. set wrong. Try connecting the tip and ring of a jack and putting this into the insert socket, if this works then it is definitely an issue with the settings on the equipment being inserted, if it does not work the mixer is faulty, but this is VERY VERY unlikely as all you are doing is inserting and there is nothing that could affect all channels unless they've forgotten to solder something on every channel.
Jul 02, 2012 | Mackie Onyx 24.4 Mixer
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
I am new . I don't no where to conect mix to
For the whole mix, there are two XLR (mic cable) sockets on the back panel labeled 'Main Output' Left and Right, if your amp has XLR inputs you should use these. Otherwise there are two jack sockets labeled 'Main Out'.
This is a complex desk with a lot of useful options, you're going to have to spend some time reading the manual. Have fun.
Jun 12, 2011 | Behringer XENYX 2442FX Mixer
I have a compaq v2000 and what Im tryin to do is conect my Mbox mini and the Xenyx 1002 to the laptop is that posible ? how can I do that ?
Should be possible. For system safety electronically, power ALL interconnected equipment from the same receptacle/plug strip. Use Balanced lines, either XLR or TRS wherever possible.
Dec 15, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Mixer doesnt send sound to my computer
If you are using recording software you will have to look for Preferences and make sure that the software is detecting your soundcard. You also have to make sure that your PlayControl settings match the input on your soundcard to the ones your mixer are plugged into. You also have to match the RecordingControl which is under Options and then Properties. That is all under Sounds and Audio Devices in your Control Panel under the Volume tab then Advanced. If you have latency problems which makes the sound delayed from the input on your mixer to what you hear from your computer try downloading Asio4all although your mixer should have come with a disk with the proper drivers. If it didn't Behringer has a great support section at their site that has downloads for everything.
Aug 07, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
66 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
