Power goes off without noticing me and touch pad won't work unless charger is removed
    Brigadier General:
  • 8,909 Answers
You don't mention the make or model but I would download a BIOS upgrade from the manufacturers web site.
Posted on Jan 04, 2011
Im trying to turn on my touchpad via control panel but when i click the box to turn it on, it wont work
go to acer.com go to support and drivers and download the driver files for the touch pad again that should solve this issue. Follow instructions to the letter and off you should go again unless the touch pad is bad mechanically.
Make sure you input the correct laptop make and model when searching their files. The driver will be there.
John
May 19, 2012 | Computers & Internet
When i put my charger my mouse pad is not working
  1. It might be due to touch-pad drivers.
  2. Use a system utility tool like Reginout to fix windows registry errors.
  3. Reinstalll Touch pad drivers.
  4. If the problem still occurs then Its due to charger. Change the charger that you are using. Use a charger whom Power(Watt) is less. Hope problem is solved.
Apr 23, 2012 | Toshiba Computers & Internet
When i put the charger in my lenovo s100 pc my mouse pad is not work
I have a Toshiba PSAF3U-0NR00V, every time i plug the charger to the laptop it goes off, but comes on without the charger, it would charge the laptop,when it's turned off but if i try turning it on...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 23, 2011 | Toshiba Satellite A205-S5804 Notebook
Microwave turns on but won't heat. it appears to be working normally but does not heat. It 2 yrs old
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jul 06, 2011 | Microwave Ovens
While charging my laptop , mouse pointer cant work and while it. why?
Hi avinamit,
I saw your question and I think I can help you with your concern.
you mentioned that when you connect your charger/Adaptor tp you laptop that the touchpad will not respond or move, I believe that your machine may be experiencing a small amount of ground from the adaptor to the touchpad, here is what we need to do,
  • First we need to turn your Laptop OFF
  • Once turned Off, remove the battery from your Laptop and unhook/remove the AC adapter/Charger as well.
  • Once the Battery and the Adapter is remove from the system, press and hold down the power button for 10-15 seconds this will drain any power left in the system, by doing this we will be starting the machine up with a new set of power coming from the Charger.
  • Once the power is drained is done connect the Adapter back to the machine and the battery try to power your system ON and check if the touch pad will work now with the adapter connected to your Laptop.
this may help you with your concern about the touch pad not responding when the charger is conencted, but still if the issue still exists then most probably the machine is grounded from the charger to the motherboard thus causing malfunction to some of your system devices.
thanks I hope this helps.
Apr 08, 2011 | Compaq Presario 700 470024-192 Notebook
Hi,my touch pad is broken,how can I replace it and how much does it costs..thanks
Before you replace the touch pad, the touch pad connect may only need re-seating.
Try removing the keyboard and re-seat and re-connect the keyboard and touch pad connector to the motherboard.
If this does not work then parts are available from these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/ www.laptoprepairco.com/ www.laptopparts.com.au/ www.laptopking.com/ www.lappy.com.au/ www.excelcomputerinc.com/ www.laptoprepairparts.com/ www.lapzone.com/servlet/StoreFront www.laptoppartsexpert.com/ www.sparepartswarehouse.com/
Mar 08, 2011 | Lifetime Acer Aspire 5738PG Replacement...
Hello My HP G60 549DX touchpad started having problems, while the laptop is charging the touchpad wont work(sometimes, not always) and the touch click wont work, i have to use the right click...
It isn't likely that your laptop charger is the problem and it is more likely that is is just your touch pad. So you shouldn't buy a new laptop charger unless you absolutely think you have to. If you do, make sure that you buy it from HP instead of a third party for a lower chance of problems. It's more likely that it's just your touch pad that is faulty.
Mar 01, 2011 | Computers & Internet
Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 29, 2007 | Microwave Ovens
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
