Question about Kohler Plumbing
Kohler manual Master shower Tower K-74-AA - Kohler Plumbing
3 Suggested Answers
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
I have a kohler 77809-aa shower tub. The drain is clogged. How do you remove the drain. I see no set screws. But I do see a couple of pins near the top of the drain cap.
If you want to clear your clogged drain you do not need to take the drain cap off. First you need to remove the over flow plate, it's located right below the faucet and has two screws, then you need to hand snake the drain line from there.
May 30, 2012 | Kohler Forte Single-Control Remote Valve...
Low water pressure
pull heads and make sure no trash in system....
Jan 24, 2012 | Kohler Home
Shower is dripping. how do you make sure you find the exact diverter replacement? Does it matter?
If you're talking about the diverter just like the one in that picture, then no. You do not need to get a Kohler diverter, as Kohler utilizes the 1/2 NPT(national pipe threading) threads that most showers are compatible to. You can pick one up from your local hardware stores. Make sure you teflon tape all the male threads before you install them.
Nov 25, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler shower valve (hot/cold switched)
Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
Dec 19, 2009 | Kohler Forte entertainment remote valve...
Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Aug 27, 2009 | Kohler Home
Kohler bath/shower diverter stem stuck on shower
Mar 14, 2009 | Kohler Plumbing
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Plumbing Logo
633 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
