Question about Dell Dimension 9100 PC Desktop
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still functions. Rich Here's the report : System Information Kit Installed: 8.9.0.1023 Kit Install History: 8.9.0.1023, Uninstall Shell Version: 8.9.0.1023 OS Name: Microsoft Windows 7 Ultimate OS Version: 6.1.7600 Build 7600 System Name: RB_PC_DESK System Manufacturer: Dell Inc. System Model: 05DN3X Processor: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz BIOS Version/Date: Dell Computer Corporation A02, 05/26/2010 Language: ENU Intel(R) Matrix Storage Manager Intel RAID Controller: Intel(R) ICH8R/ICH9R/ICH10R/DO/PCH SATA RAID Controller Number of Serial ATA ports: 6 RAID Option ROM Version: 8.7.0.1007 Driver Version: 8.9.0.1023 RAID Plug-In Version: 8.9.0.1023 Language Resource Version of the RAID Plug-In: 8.9.0.1023 Create Volume Wizard Version: 8.9.0.1023 Language Resource Version of the Create Volume Wizard: 8.9.0.1023 Create Volume from Existing Hard Drive Wizard Version: 8.9.0.1023 Language Resource Version of the Create Volume from Existing Hard Drive Wizard: 8.9.0.1023 Modify Volume Wizard Version: 8.9.0.1023 Language Resource Version of the Modify Volume Wizard: 8.9.0.1023 Delete Volume Wizard Version: 8.9.0.1023 Language Resource Version of the Delete Volume Wizard: 8.9.0.1023 ISDI Library Version: 8.9.0.1023 Event Monitor User Notification Tool Version: 8.9.0.1023 Language Resource Version of the Event Monitor User Notification Tool: 8.9.0.1023 Event Monitor Version: 8.9.0.1023 Array_0000 Status: No active migrations Hard Drive Data Cache Enabled: Yes Size: 1863 GB Free Space: 0 GB Number of Hard Drives: 2 Hard Drive Member 1: ST31000528AS Hard Drive Member 2: ST31000528AS Number of Volumes: 1 Volume Member 1: ARRAY0 ARRAY0 Status: Degraded System Volume: Yes Volume Write-Back Cache Enabled: No RAID Level: RAID 1 (mirroring) Size: 931.5 GB Physical Sector Size: 512 Bytes Logical Sector Size: 512 Bytes Number of Hard Drives: 2 Hard Drive Member 1: ST31000528AS Hard Drive Member 2: ST31000528AS Parent Array: Array_0000 Hard Drive 0 Usage: Array member Status: Normal Device Port: 2 Device Port Location: Internal Current Serial ATA Transfer Mode: Generation 2 Model: ST31000528AS Serial Number: 5VP606AS Firmware: CC46 Native Command Queuing Support: Yes Hard Drive Data Cache Enabled: Yes Size: 931.5 GB Physical Sector Size: 512 Bytes Logical Sector Size: 512 Bytes Number of Volumes: 1 Volume Member 1: ARRAY0 Parent Array: Array_0000 Hard Drive 1 Usage: Array member Status: Failed Device Port: 3 Device Port Location: Internal Current Serial ATA Transfer Mode: Generation 2 Model: ST31000528AS Serial Number: 5VP6051X Firmware: CC46 Native Command Queuing Support: Yes Hard Drive Data Cache Enabled: Yes Size: 931.5 GB Physical Sector Size: 512 Bytes Logical Sector Size: 512 Bytes Number of Volumes: 1 Volume Member 1: ARRAY0 Parent Array: Array_0000 Unused Port 0 Device Port: 4 Device Port Location: Internal Unused Port 1 Device Port: 5 Device Port Location: External CD/DVD Drive 0 Device Port: 0 Device Port Location: Internal Current Serial ATA Transfer Mode: Generation 1 Model: HL-DT-ST DVD+/-RW GH50N Serial Number: K1CA79H1440 Firmware: B103 CD/DVD Drive 1 Device Port: 1 Device Port Location: Internal Current Serial ATA Transfer Mode: Generation 1 Model: HL-DT-ST BD-RE BH30N Serial Number: K95A6AK4928 Firmware: A102
    Guru:
  • 679 Answers
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Posted on Jan 04, 2011
Ford Escape 2011 Fuel Delivery Diagram. Ran my scan tool and had P0455 and P0456 and found the Canister Purge Valve next to my Throtle Position Sensor was degraded by leaking vacuum. Replaced Sensor
Most likely the sending unit attached to the fuel pump module is the source of the erratic fuel gauge. The fuel pump is located in the fuel tank and can be accessed through a panel located under the drivers rear seat.
Oct 09, 2016 | Ford Cars & Trucks
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Mar 07, 2014 | Dell Dimension Computers & Internet
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
I have a Fujitsu Siemens AMILO Laptop, It is not in great condition.. (I got it from a friend for my Son, just for use of the Internet)Initally it was working ok, I was getting a notification...
It seems like the Windows operating system is having problems. That could be due to a faulty hard disk, especially if as you say it's not in great condition. The only way to be sure of that would be to test the hard disk by booting of a CD/DVD with some diagnostic tools to check the hard disk's condition.
If you have access to another computer, you could download and burn the "Ultimate Boot CD" which includes such diagnostic tools. After that, insert it to your laptop and try booting from that and running one of the several Hard disk diagnostics to see if it finds something.
Another possibility would be that just the contents of the hard disk are corrupted, while the hard disk itself might be on good working condition. If that is the case, it will show up after running the diagnostics above. To fix that however, you might need to re-install Windows on the laptop from a Windows CD-ROM, depending on how severe the issue might be.
Mar 13, 2011 | Fujitsu AMILO PC Laptops
Dell XPS w/Mirrored drives. No C drive when using boot disk.
As RAID uses block for block copy, a re-sync when adding in a new mirror on RAID 1 will take some time, and system performance will be affected during that time period. There is no indication in windows if the rebuild is complete as this is being done on a hardware level by the controller. Both Raid 5 and RAID 10 have added benefits , but alos require more storage (a lot more in case of RAID 10 as you will have effectivly 3 spares for 1 data.) Raid 5 has the best space/protection pay off, but will be slightly slower than both RAID 1 and RAID 0 as parity has to be calculated for each write. As caffineshark states your best option is to use a combination of the methods we have described:
1) Use the two SATA disks as RAID 0 for performance and reliability.
2) Make backup images of the boot volume using Drive Image / Ghost and store on external USB IDE drive, and then offsite.
If you make an image in the USB drive, make sure you run a verfiy of the image after creation to make sure it's valid.
This should allow you to restore in a DR sutuation, but also give you some decent HDD crash protection.
Jan 29, 2010 | Dell My XPS M2010 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
1 logical harddisk degraded, RAID Poweredge
Revert back to original configuration of hdd in your RAID setup. Boot to SCIS BIOS and double check functionality of hard drives. The error is probably telling you that Disk1 is degraded because disk 0 is failing and you removed the wrong hard drive.
Jul 11, 2009 | Dell Computers & Internet
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Computers & Internet
Dell Dimension 9100 PC Desktop Logo
258 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
