SOURCE: air bag light
if the air bag stays on that means you have a problem with the air bag system, and you need to have it diagnose, but if you just bought the sedona from a used car dealer they have to fix it, it is part of the safety inspection requred by law
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
SOURCE: my 2003 kia spectra stalls
It might have a partially blocked fuel line or ait intake supply.
or the fuel sensor might be malfunctioning.
Try to check the compression, it might be loosing compression when you demand the engine to move the vehicle.
SOURCE: 2004 kia spectra no a/c
needs looking at because it could be switch that allows it to turn on if sufficient gas is present ,or a problem with the clima compùter ,but to do anything you will need the special machine to empty the system then check things out so take to an authorised AC garage ,because these systems are a potential accident and you could lose a finger with frostbite in a matter of less than 2 seconds .therefore i will not tell you how to look for a soloution because of the dangerous nature of playing with air con
