No display after changing batteries - Heating & Cooling
  • 73 Answers
What Name & Model System ?
Posted on Jan 04, 2011
I changed batteries but still no display n thermostat don't light up. pro1iag model T701. What to do?
Verify that you in fact replaced the batteries with GOOD batteries. If you can separate the thermostat from the sub-base, hold it in your hand and replace the batteries again. If the display does not come up at that point, it is time to change the thermostat.
Apr 22, 2015 | Heating & Cooling
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
How do I change from Km to Miles on the odometer for a Rav 4 (2006)?
Disconnect the battery for 90 seconds, then unplugged the cluster.. Then connect the battery with no cluster.. HVAC display changed to metric...
Re-connected the cluster again, display changes to imperial...
The cluster is what dictates what is displayed. It is metric by-default but a US imperial instrument cluster overrides that.
Jun 29, 2011 | 2008 Toyota RAV4
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
Big tic no longer changes color
The big tic has two batteries. The battery for the display may need to be changed and the circuit reset. You can then hold the display button down for 2.5 seconds to cycle through the display function.
Sep 17, 2009 | Fossil JR8096 Wrist Watch
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Conon powershot a470 i cant find in the manual where the battery life is displayed? is it on the screen? do u have 2 change setting 2 find it? or does this model not display it on the screen?
Your a470 has a "low battery" flashing icon that will appear in the upper right hand corner of your lcd display when the battery is getting low. It doesn't appear to have a constant battery display. The manual recommends when you see the flashing icon... change the battery as soon as possible.
May 15, 2009 | Canon PowerShot A470 Digital Camera
Changed batteries, zeros are in display but no key response
Perhaps a the connections are dirty (battery connections) or you may have the wrong battery type/model
Feb 11, 2009 | HP 12c Calculator
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
