Question about Compaq Presario 700 470024-192 Notebook
My touchpad has ceased to work. When I use it the cursor flies all over the screen. I am using an external mouse which defeats the object of a laptop-wires etc.
    Sergeant:
  • 261 Answers
This is due to some applications your cursor doesn't work or it fly over the screen automatically uncontrolled.try rebooting system when it happens.
hoping it will help u
thnx
Posted on Jan 04, 2011
When I plug in an external mouse, it won't click.
If an external mouse does not work correctly, you may need to install device drivers for it. Windows does not support all 'mice' just by plugging them in. Download and install the drivers for the mouse from the manufacturers web site. Do NOT do a factory recovery for a device driver problem.
Jun 29, 2014 | Lenovo IdeaPad Yoga 13
My compaq presario v2000 built in mouse is not moving while the external mouse is working what do I do to fix this problem
alright, so you're saying that the touchpad ceases to function when you have the external plugged in? that is probably normal behavior set in the mouse settings in control panel, if you're saying it's not working at all there should be a button to the right of the touchpad that is used to enable and disable that device.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 22, 2012 | HP Compaq Presario V2000 Notebook
Cursor/touchpad is not working on my compaq
First option try to connect external USB type mouse, if it's working. second option need your touch pad check-up software driver in the device manager area. need update. or try to restore your operating system (OS). back to the time that working properly your touchpad advice.
Let me know if not yet working your touchpad. try that solutions first.
Oct 18, 2011 | Computers & Internet
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
My cursor on my Dell inspiron 1525 laptop is stuck in the middle of my screen the touch pad isn't working either I was wondering how i could fix this
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
Apr 23, 2010 | Dell Inspiron 1525 Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
My cursor flies all over the screen and ends up in the top right corner of my screen all the time no matter what i'm doing. It seems to right click as it does it. Why is it doing this?
your touchpad is not working right. Use a USB mouse and disable the pad until you can get the pad replaced. Also, check the mouse drivers to make sure they are correct and up to date.
Nov 19, 2009 | Dell F3534 Touchpad
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
Jumping cursor
You need to adjust the sensitivity of the touchpad
In the TouchPad Properties window you can access additional TouchPad preferences.
»To access the TouchPad Properties window, use the TouchPad to select Start > Control Panel > Printers and Other Hardware > Mouse > Device Settings, and then select the Settings button.
(If you follow this path using an optional external mouse, the TouchPad Properties window may be unavailable.)
Dec 10, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
