Question about Ovens
Dear Experts, I have a problem with Bosch oven, model HBC86K753. The microwave mode switch off singly after 22-23 sec of program start. Could you please give me your recommendations for resolution of this problem. Thank you in advance. Fyodor
  • 213 Answers
SOURCE: Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Posted on Nov 26, 2007
  • 110 Answers
SOURCE: Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
Posted on May 30, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: bosch hba34b520
    Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
    A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
    If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
    I must stress that this only applys to a single oven and not a double one.
    Plz rate my solution.
    Thanks.
    Posted on Jan 14, 2009
    • 1417 Answers
    SOURCE: My built in Bosch oven
    hello,
    what this error code simply mean is that there has been a loos of wire some well or an over flow of liquid substance located on the panel of the oven by the screen sensor.
    please fill free to get back to me for more information or way out
    hope this help?
    thank you and thanks for using fixya.
    Posted on Sep 08, 2010
    I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
    the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
    Dec 27, 2015 | Bosch Ovens
    I have a Bosch built in oven and don't know how to set the time on it
    turn the oven off at mains for a few secs. When you turn it on the display should flash 0.00 or 12.00. Press the clock button once ( don't hold it in) use the + or - to set time. Once time selected don't press anything else after a few secs the oven will register and hold you selection.
    Apr 03, 2013 | Bosch "27"" Single Wall Oven 500 Series -...
    Bosch wall oven turns on when mcrowave is on
    Contact Bosch website and ask customer services if they have had this problem before. It may be subject to recall if there is a fault. Also have a word with the installer. If there is any leakage of radiation it MUST be stopped.
    Dec 10, 2017 | Bosch Appliances 27 in. Wall Oven Electric...
    BOSCH HBL3450UC Single Oven weak/slow pre-heat
    I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
    Dec 19, 2012 | Bosch HBL3450UC Single Oven
    Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for...
    My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
    Oct 15, 2010 | Bosch HBC 86Q650B Electric Single Oven
    Need selector switch for upper oven
    If you are in the u/k, then try these sites
    WWW.ESPARES.CO.UK/BOSCH
    WWW.4BOSCH.CO.UK/SPARES
    If elsewhere, then type in BOSCH SPARES in the your browser bar, and you should be able to find someone who supplies Bosch spares.
    Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
    Bosch oven function error e124
    Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
    Unfortunately the error codes for Bosch are different depending on the model of the unit.
    Thank you, I`ll look for your reply.
    macmarkus :)
    Jan 09, 2010 | Bosch Ovens
    How to set the time on a bosch single oven hm48141
    I some how got mine into engineering mode so switched it off for a few seconds.
    The time should then blink, press the Clock button briefly and 12:00 shoul appear, then press + or - until desired time is reached then 'Clock' again
    Nov 29, 2008 | Bosch Ovens
    Ovens Logo
    32 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
