DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
    Brigadier General:
  • 8,909 Answers
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Posted on Jan 04, 2011
Zenith tv,no picture only one line comes across the screen when ever i turn it on (model SM2573BT)
look for the vertical ic at the main board, check for shorted pin or the ic get burned.if the ic get bad you need to check shorted diode near the ic which may the cause why the vertical ic get defective.
Aug 08, 2012 | Televison & Video
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
DEAWOO CTV MODEL NO.DTC2975 I wan to number of Vertical ic.
Hello
It may be either TDA8357J OR TDA8358J. Both are equivalents. OK.
Jan 04, 2011 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Vertical failure on this chassis. what is the part # for the replacement Vertical Amp IC. And do you recomend changing any of the capacitors on the output lines?
This unit is listed in the flat panel section. If it is indeed a flat panel TV it doesn't have a vertical output IC. If it is a crt type you need the brand, and exact model number to have any hope of getting a part number.
Apr 12, 2010 | Televison & Video
Thin vertical line, high tension problem ? IC location?
Check the picture below to find the vertical IC. The markings on the body are: LA7837.
Mar 06, 2010 | Hitachi 32UX59B 32" TV
What would cause a straight line threw tho middle of my tv monitor. I have a zenith model number z27h96r8.
If this is a straight white line you may have a vertical collapse. You need to either solder bad connections at Vertical IC or change the vertical IC
Apr 23, 2009 | Zenith Z27H96R 27" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
