Question about Coleman Mach 15 Air Conditioner
Hi we have bought a second hand caravan with a Coleman TSR air conditioner. The fan works and it sounds like the unit is trying to kick in it sppeds up for a while and then slows down. It dosn't get cold, we have cleaned the filter. We don't know how old it is or if they need re gassing can any one help with some ideas. Regards pauline
  • pauline280 Jan 04, 2011
    Thanks I will try all of those suggestions, its pretty old but when we bought the van we tried it and it worked but its been sitting for about 6 months with no use.
    Genius:
  • 1,015 Answers
The first thing I would do is to give the unit a thourgh cleaning around motor and fan. Blow out with compressed air if possible and brush and vacumn out what you can get to.Check for oil ports on motor and add a few drops of fine grade of machine oil. If it's very new it is probably sealed bearing and no lubrication is possible.
If it is very low on freon the compressor may try to start then shut down due to low pressure. If it has service ports on it and you have ref. gauges you can see what the pressure is without the compressor on then switch it on and see what happens.If there is no change in pressure then compressor is not working and I would slowly add freon to see if it will start. I hope this helps you some. Thank you
Posted on Jan 04, 2011
  • Jack Spooner Jan 04, 2011
    Thats good to know that it was working. Don't know what your location is but if it gets very cold where you are and it been setting that long then I would feel much more confident that adding some freon will help you. These units have rubber o-ring seals and are known for leaking if not used regularly to keep them lubricated. Best of luck and have a good new year. Thank you
Aircon regasing
There is a specification plate on the base of the unit. It will have the refrigerant type and quantity listed. The leak should be found and repaired before re-charging with refrigerant.
1993 model could be r-12,r-22 or r-134a.
Oct 13, 2009 | Coleman Heating & Cooling
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
Aug 17, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
COLMAN TSR
3000 Watts is a little short on the power necessary for the compressor to restart. When it compressor starts it may draw 27 amps or more for a split second. 3000 / 120 = 25 amps. when the fan slows down it is telling you the voltage has dropped and it doesn't have enough power. After the pressure has balanced out in the A/C system the compressor can start against no pressure difference.
Jun 16, 2008 | Coleman Mach 15 Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
May 21, 2008 | Coleman Mach 15 Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
91 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
