Question about Belling Microwave Ovens
The ovens in my belling classic ninety deluxe will not heat beyond 110 degrees. what is wrong with it?
    Brigadier General:
  • 8,909 Answers
Probably thermostat is faulty.
Employ a Belling Approved appliance engineer to check and replace it if in needs replacing.
Posted on Jan 04, 2011
My microwave will run but it doesn't produce any heat... We have been having quite a few power bumps lately...
This is classic door safety interlock switch failure. Remove the cover and check the micro switches you will find near the latch. If they are failed, the oven can't tell if the door is closed ... door not closed, the oven will not turn on the heat.
If the switches check out ... it could be the capacitor ... you can't and shouldn't test this beyond removing and reinstalling the leads. The capacitor stores a LOT of power and can be lethal. Shorting the device out can be dangerous. Proceed at your own risk.
Oct 06, 2010 | Whirlpool Microwave Ovens
We have Maytag Model: VM12AV-1, microwave oven. This morning when I pushed the start button to heat for a 40 second period all powwer on microwave went out. I checked the power outlet to oven, and we had...
All the possible problems will mean removing that thing...it is likely that a fuse inside blew, but that may be a sign of bigger problems...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 04, 2010 | Maytag MMV5186A Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Comes on but will not heat/microwave. We have moved to france from Ireland and it worked fine for a few weeks but now will not function.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
yfsf
Aug 13, 2009 | Belling BIM60 Microwave Oven
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time....
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Aug 12, 2008 | GE Microwave Ovens
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
