I need to know which is the part number of the DDR3 bulded iside the Lenovo ThinkPad Edge 15 0301-GQG leptop?
    Brigadier General:
  • 8,909 Answers
Manufacturer Part: 55Y3706
2 GB (installed) / 4 GB (max) - DDR3 SDRAM - 1066 MHz - PC3-8500 ( 1 x 2 GB )
So you need DDR3 SDRAM at 1066Nhz PC3-8500
If you are running 64bit Software then upgrade to 8GB (2 X 4GB sticks) otherwise your OS may not recognise any more that 2 MB
I need to know which - c0006679.jpg LenovoMemory - 1 GB - SO DIMM 204-pin - DDR3 - 1066 MHz / PC3-8500 - 1.5 V - unbuffered - non-ECC Manufacturer Part: 55Y3706
Posted on Jan 04, 2011
Think pad edge e531 thermal sensing error
Sorry but the only solution is to replace the motherboard. Check lenovo site http://support.lenovo.com/en_US/product-service/warranty-status/default.page?
as your warranty may still be in effect and the cost free. Otherwise, they are around $200 and you will also need a boot thumb drive to set up the new mobo with serial and model number.
Feb 17, 2014 | Lenovo ThinkPad Edge E531 Laptop
Can't get my ThinkPad Edge E530 (3259-78U) to aknowledge drivers for the networking
Go to the Lenovo website click on drivers & software then enter your model number and then select your operating system and you will find all drivers for your ThinkPad Edge E350.
Jan 11, 2014 | Lenovo ThinkPad Edge E530 3259-78U...
Trying to get to the bios menu on a ThinkPad Edge E530 (3259-78U)\
As soon as the Lenovo logo appears press F1 a few times and it should access the bios.
E320 2007 battery replacement
Lenovo ThinkPad Edge E320?
I don't think you are referring to the Main battery......
However;
1) There is a slide button on each side of the Main battery.
Both are slid to the outside edges of the laptop, then the main battery is slid out. Out towards the outside of the laptop.
I believe you are referring to the CMOS battery.
Also known as the RTC battery. Real Time Clock battery.
From what I can see the ThinkPad Edge E330 is VERY similar to the ThinkPad Edge E320.
What you need is the HMM. Hardware Maintenance Manual,
http://www.manualowl.com/m/Lenovo/ThinkPad-Edge-E330/Manual/309892
Use the Right Arrow on the right side of the number 100, at the top; to go down through the pages.
Page 61 for Main Battery Removal/Replacement
(Starts on Page 60 - 1010 Battery Pack. Bottom of page)
Page 70 for RTC Battery Removal/Replacement
Bottom of the page - 1070 Backup Battery
As you can see you just remove the screws, (Philips. Use No.1 Philips screwdriver, or equivalent Jewelers screwdriver), for the Bottom Cover, and remove the Bottom Cover.
(It's a panel. It is not the Base Enclosure/Bottom Cover)
Then unplug the small white male plug connector, on the end of the RTC Battery's wires; from the motherboard.
Remove the RTC Battery, and replace.
This shows you in a video, but a different Lenovo ThinkPad Edge laptop.
Principle is still the same,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=PD021754
KNOW THIS HOWEVER........
Your body carries Static electricity. When that Bottom Cover is removed, all of the Static shock sensitive hardware components are exposed.......
You need to make SURE your body is relieved of Static, BEFORE reaching to unplug that RTC battery, or remove it.
Better still is to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
Average cost is around $3 to $6.
Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Example of RTC Battery,
http://www.ebay.com/itm/COMPATIBLE-Backup-RTC-CMOS-BIOS-BATTERY-CR2032-FOR-IBM-Thinkpad-02k6541-/251250253852?pt=Laptop_Batteries&hash=item3a7faea01c
Now I did NOT state that this was THE RTC Battery you need.
Just stating that is what it looks like.
Know this;
ALL of these batteries produce 3 Volts DC.
They use a CR2032 watch type battery, that is commonly used in a desktop computer.
All you need to make sure of, is the Male Plug Connector is correct.
Yep. That's it.........
If you HAVE to, you could cut the wires on the new RTC Battery, cut the wires on the old RTC Battery, and PROPERLY splice the old RTC battery's male plug connector to the new one.
Use heat shrink tubing, and solder the wires together.
Remove RTC Battery to reset a password?
Nope. Don't think so.
There should be a capacitor, or capacitors; that store a small residual charge of power -> INDEFINITELY, even after removing the RTC Battery. (CMOS battery)
CAN I be wrong? Yep. Depends on manufacturer, and year made.
Replace RTC Battery because it's no good?
Yes. Sure.
Looking at the Base Enclosure, (Bottom Cover), is part of what makes me think the E330 is very close to the E320,
http://www.pcworld.idg.com.au/review/notebooks/lenovo/thinkpad_edge_e320_129834m/397569/images?image=5
http://support.lenovo.com/en_AU/product-and-parts/detail.page?DocID=PD024121
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 17, 2013 | Computers & Internet
I have a lenova 9704-A36 pc with vista installed came with 1gb of ram. Want to upgrade, where to find compatible memory
52757437-260x260-0-0_lenovo+2gb+pc3+8500+1067mhz+ddr3+ecc+sdram+memory.jpg Mouseover to zoom or click to enlarge Lenovo DDR3 2 GB SDRAM (41U5252) $57.00 1 store
  • Technology: SDRAM
  • Form Factor: DIMM 240-pin
  • Capacity: 2 GB
  • Modules Qty: 1
  • Bus Clock: 1066 MHz
ahr0cdovl3d3dy5jb21wdxrlcnnzywxllmnvbs5hds9zag93aw1hz2uucghwp3byb2r1y3q9mtaznzgmaw1hz2u9mcz0exblpwxhcmdl==.jpg
Lenovo 1GB DDR3-1066 Memory Module for Notebooks
Improve overall performance of ThinkPad systems by upgrading with additional memory. PC3-8500 DDR3-1066 low-halogen SODIMM memory offers maximum data transfer rates up to 1066MB/sec(1) to help you increased performance of memory intensive applications such as streaming video, graphics and CAD programs. Adding more system memory is one of the least expensive ways to help boost overall notebook system performance and allows more multitasking which saves time and hassle.
May 02, 2012 | Lenovo Computers & Internet
I need drivers for lenovo thinkpad edge wifi
Go to the link Driver and download Networking:
Wireless LAN driver .
Thanks for using FixYa.
May 30, 2011 | Computers & Internet
How can i know my RAM TYPe and speed ??
The best way to know what you need is to search for it on the web type in "Thenameofyourcomuter""specs"
if your comptuer is the Lenovo ThinkPad R400 notebook
then your specs are
RAM Configuration Features 1 x 2 GB Memory Specification Compliance PC3-8500 Technology DDR3 SDRAM - 1066 MHz Installed Size 2 GB / 4 GB (max) Form Factor SO DIMM 204-pin
Witch means its only upgradable to 2 gigs.
to see what is in thier now start your computer up, Go to my computer, right click on it and go to properties. Under that it will show information about your comptuer.
Dec 20, 2009 | Lenovo ThinkPad R400 Notebook
Computers & Internet Logo
David Payne
David Payne
