Question about Toshiba Qosmio G25-AV513 Notebook
I turn it on and it goes to a screen that says: "Checking file system on C: The type of the file system is NTFS. volume label is s3A5802D002. one of your disks needs to be checked for consistency. You may cancel the disck check, but is strongly recommended that you continue. To skip disk checking, press any key within 10 sec" I pressed any key but it does nothing, and this message stays on the screen and nothing happens at all. Please help. How do I get rid of this as its only just started happening
  • 3 Answers
You must execute the full scan-disk process. So that when you start again it will not view.
Posted on Jan 04, 2011
I am converting Fat to NTFS convert l:/fs:ntfs the drive is 2gb what do i enter for the volume label for that drive
You need to locate the current volume label on the drive.
The easiest way to do this is from the command prompt, you type in vol(space) then the drive letter you are converting & press enter. It will then tell you the volume name, and then on the second line the serial number for the drive.
Oct 07, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run...
Hide Your HDD Partitions Hide your HDD partitions 1. Go to Start > run > type “diskpart”.
a dos window will appear with following like that
DISKPART> 2. Then type “list volume” without quote
It will look like this.
Volume### Ltr Label Fs Type Size Status Info
Volume 0 F CD-ROM
Volume 1 C NTFS Partition 7000MB Healthy
Volume 2 D soft NTFS Partition 8000MB Healthy
Volume 3 E —- NTFS Partition 8000MB Healthy
3. If u want to hide drive E then type “select volume 3′ without quote
then a message will appear in same winwods { Volume 3 is the selected volume}
4.now type ” remove letter E” without quote
now a message will come { Diskpart Removed the Drive letter }
sometime it requires the reboot the computer .
Diskpart will remove the letter .Windows XP is not having capabilty to identify the unkown volume.
Don’t afraid ur Data will ramin same .
to Come back the Drive repeat the process . but in 4th step which is shown in this post replace ” remove” to “assign
means type ” assign letter E” without quote
The above method won’t work for the drive containing Operating System and it can also be done using System Manager>Storage Manager
on Jan 26, 2010 | Computers & Internet
Online ups having not backup
Hetman NTFS Recovery recovers files and folders from all types of hard drives formatted with NTFS, including SSD drives and external storage. The NTFS file recovery tool can perform a simple undelete operation to recover deleted files or perform a comprehensive data recovery procedure, extracting all files and folders from the damaged NTFS volume complete with the original folder structure.
Hetman NTFS Recovery recognizes and recovers NTFS alternate data streams, and supports the recovery of compressed and encrypted files. The NTFS recovery tool works in all 32-bit and 64-bit versions of Windows including those that do not natively support the NTFS file system.
Key features
• Offers the best value to users of modern versions of Windows (Windows XP and up) thanks to exclusive support for the FAT file system;
• Unformat formatted partitions and restore original volumes from repartitioned hard drives;
• Undeletes all types of files including pictures, music, videos, documents etc.;
• Recovers data from formatted, corrupted and inaccessible NTFS disks and SSD drives;
• Restores files from formatted NTFS volumes and repartitioned disks;
• Extracts information from volumes with broken file systems, damaged partition tables and master boot records (MBR).
I also attached a link to the video instructions and a link to the site
Jun 13, 2013 | Office Equipment & Supplies
How to recover my tally7.2 company password
Key features
Jun 07, 2013 | Cell Phones
Youtube removed ,how restored n o ki y a E5
5af5bbf4-ede6-42a6-94a0-f75eff3922b9.jpgHetman NTFS Recovery recovers files and folders from all types of hard drives formatted with NTFS, including SSD drives and external storage. The NTFS file recovery tool can perform a simple undelete operation to recover deleted files or perform a comprehensive data recovery procedure, extracting all files and folders from the damaged NTFS volume complete with the original folder structure.
Key features
Apr 30, 2013 | Cell Phones
How to restore factry default settings
Key features
Apr 18, 2013 | Office Equipment & Supplies
I turn it on and it goes to a screen that says: "Checking file system on C: The type of the file system is NTFS. volume label is s3A5802D002. one of your disks needs to be checked for consistency. You...
the time it takes depends on the hard drive size but you push esc or enter as these are primary keys or let it start go have a coffee then come back to it.
Oct 06, 2010 | Toshiba Qosmio G25-AV513 Notebook
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Will not boot up. checks file NTFS volume label S3A6261D001 quotes unspecified error occurred
You could spend a long time diagnosing troubles, but I would simply reload the operating system, using the manufacture-supplied software. If you have a hardware problem, the new operating system either won't load or won't run when your finished.
Mar 21, 2010 | Toshiba Computers & Internet
Toshiba Qosmio G25-AV513 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
