Question about Sentry Security Safe with Electronic Lock with override key
I have a Sentry T8-331 and it won't unlock to either my code or the factory default code. Thankfully the door is open so not stuck shut, but i want to be able to use the safe again. Sentry have replaced the keypad for me, but this didnt fix it. It seems as though the chip/board has forgotten the factory number. How I can fix or replace? cant find anywhere in the UK to resolve this problem. Sentry have no chipboards in stock and wont get anymore due to the safe being discontinued,
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: Sentry H4100 file safe
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
Posted on Sep 10, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 57 Answers
SOURCE: I have a sentry fire safe with an electronic lock
Normal 0 I found this hope it will help. So I called the sentry safe company, (800-828-1438), and waited for about 10 minutes to speak to a representive, (that was alright since I have a speaker phone). The first thing they asked me was about the condition of the batteries. I told them that they were brand new. The person then asked about the brand name and expiration date of the batteries. They were generic batteries, but the expiration date was fine. They suggested a new set of batteries, and mentioned that I could bypass the battery pack, (which sometimes fails), by unplugging the pack and using a regular 9 volt battery.. So just to cover the base, I went down to the store and obtained a brand new 9 volt duracell battery. I unplugged the battery pack and plugged in my new battery. I then pushed the combination numbers and my safe again failed to open.
I called the sentry company back using my speakerphone feature again while waiting to speak with a technician. The tech asked me about the batteries and I told him it had a new 9 volt at the last technician’s recommendation. The person began to talk about the actuator cylinder inside the safe, stating that it did not sound like it was actuating. Then they told me something that really made me wonder about the quality of this safe. They told me I would need to hit the safe with a rubber mallet in an attempt to get the actuator to engage so I could open the sentry safe. OK, so the safe is supposively built to keep my belongings safe from thieves and fire, but now I am going to fix it with a rubber mallet? Good thing my sentry safe was inside, somebody might have wondered about my mental state if they had seen me beating this fireproof safe with a rubber mallet! (PS: If you use the rubber mallet option or any other suggestions that sentry’s customer assistance supplied, and have firearms or dynamite in your safe, you do so at your own risk, use wise judgement for your own safety)
Well it just so happens that I had a rubber mallet and did not need to once again go to the store to get something to personally fix my great sentry fireproof safe. So I begin beating the sentry safe with this mallet and then tried the combination again. Woolah, It opened! I stopped for a moment and began to ponder how many other things I could fix with this magical rubber mallet. I mean, what about the TV, the computer, my fridgerator and that cell phone that always drops calls? Could it be that I have discovered the fix all to all mechanical issues? As I began to look at my belongings in my fireproof safe that I have just opened with a rubber mallet, I thought "so if I close the safes door will I need a sledge hammer next time"?
Time for another phone call, back to the speakerphone. The technician this time listened to my issue and asked me if I had some lubricant like WD-40 with a small tube that attaches to nozzle. I thought, "well of course I do, I was just using that to fix the broken water pipe in the garage." The phone tech tells me where to spray the lubricant on the inside of the sentry safe door. He has me do this in the open and closed combination positions, and it’s now opening when I press the combination numbers with the door open, hurray! The only problem is that after working in the lubricant a few times the handle on the door does not lock into the locked position. I no longer need the combination to unlock my safe, I only need a can of lubricant! OK, this is one really tough safe, what thief would ever think that they would need a rubber mallet and a can of silicon lubricant to open up a safe?
Back to the speakerphone, this time a lady technician. She wants me to get a screwdriver and pry off the plastic piece on the back side of the door. At this point I said to her, you have built a product that I need to have a rubber mallet, a can of 3 in 1 spray lubricant, and a screwdriver to open? She stated that she was doing all she could to help me fix my safe and asked me how long I had owned the safe. I told her about 2 years and she stated that it was out of warranty. I thought, well who needs a warranty when they have a magical mallet, a can of black led, and a screwdriver? Anyway she directs me to pry the plastic backing off of the door and when I do this little piece of plastic falls out onto the floor. I look at this little plastic piece pondering in my mind, what’s it’s part in all of this. Well the technician is directing me to look at the arms and gears and some arrows that line up between the metal arms and plastic gears. What’s wrong with that picture? Metal and plastic don’t really work together long before the plastic breaks. I had to wonder for a moment, is this some really expensive fireproof plastic? The arrows line up and with that information she directs me to the area of the actuator again, she says "you see the circuit board" and a little white button that sticks out from it?" I said well yes, I see the circuit board and the little white button you are talking about seems to be laying on the floor broken off. So I picked it up and said, "this little broken piece of plastic that connects to the metal arm on the safe is why the safe does not work right?" She tells me yes that’s the problem, that i have broken it and since it’s out of warranty that there is nothing she can do to help me. But she then asks me to hold on for a moment…..
She comes back to the phone sounding sincere, like she has just solved all my problems, and tells me that she has spoke to her supervisor and that they can offer me 10% off on any safe that I would like to purchase. I thought what great customer service, now they want to sell me another safe with metal and plastic pieces that break and give me a huge discount of 10%, and I bet it comes with a free maintenance kit which includes a polo stick, some lard oil, and a screwdriver on the rocks! Needless to say I declined their gracious offer.
I will say that all the organizations personnel, (that I spoke with), were courteous and trying to be helpful, (that was within the realm of authority they were given). With a product such as this, and the great customer service I experienced, I thought it was probably best to find a safe that was free of little plastic pieces that break off, cause those plastic pieces won’t save you 10% !
Posted on Oct 08, 2009
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Need factory code to my parents' sentry safe a5865.
So that is it! If Sentry will not give it to you, what makes you think someone out here has the code?!?!?!!?
Nov 22, 2015 | Home Security
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
My Sentry safe MS0100 combination dial will not turn. I can open the door but can not turn the dial to lock it.
If the safe is brand new.. you must first remove the locking screw at the base of the combination lock dial lockcase.. discard the screw.. Make sure you have the owners manual with the sticker and default lock code nearby before locking the safe.
The factory has a preset combination code that cannot be deleted. It is on the owners manual. You can use that code if your codes have become compromised.
Also ensure the batteries are fresh. This may also be the problem.
Anything beyond this will require assistance from Sentry. Your serial number is on the side of the door. Have that ready.
www.sentrysafe.com
Best of Luck
Apr 16, 2011 | Sentry Fireproof Safe
Sentry safe, enter codes and nothing
Motorola IC #MC68HRC705 will not reset. Chip is most likely bad. Time to throw this safe out...Thanks for your answers. George
Mar 25, 2009 | Sentry Fireproof Safe
Mar 22, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
Sentry Security Safe with Electronic Lock with override key Logo
204 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
