Question about Emerson MW8991SB Microwave Oven
My turn table doesn't turn on my microwave (Emerson MW8991SB)
    Brigadier General:
  • 8,909 Answers
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
But here is a basic methos if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Posted on Jan 04, 2011
Replacement glass turntable
Go to www.ebay.com Type make and model of microwave oven, refine search to plate.
Jul 11, 2012 | Emerson MW8991SB Microwave Oven
The ceramic fuse has expired in my microwave (Emerson MW8991SB). Will you tell me where the fuse is located?
On my own microwave I have noticed there is a panel on the interior wall with removable screws...I'd suggest UNPLUGGING it first (of course!) then checking out the interior of that.
May 18, 2011 | Emerson Microwave Ovens
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
Microwave is not heating food it turns two red lights on when trying to heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 07, 2010 | Emerson MW8991SB Microwave Oven
My microwave sparks when I turn it on.
Its called arcing, its either the card needs replacing (in the cabinet)or the the magnetron is sick and make sure its nice and clean in the cabinet
Oct 18, 2009 | Welbilt MR622W Microwave Oven
Need a manual for MW8991SB
Hi
Thanks for using FixYa. You can view/download the manual for your Emerson MW8991SB Microwave from this link--
Emerson MW8991SB Microwave Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 06, 2009 | Emerson Microwave Ovens
Emerson 900 Watt Microwave MW8991SB glass turntable broke in two Replacement parts anyone?
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Mar 02, 2009 | Emerson MW8168B Microwave Oven
Mircowave oven
CHECK THE PROBLEM ON THE BURN THERMAL FUSE ON YOUR UNIT.
Aug 16, 2008 | Emerson MW8107WA Microwave Oven
Need plate inside
try partstore.com
or
microwaveglasstrays.com
Feb 22, 2008 | Emerson Black Microwave Oven
Emerson MW8991SB Microwave Oven Logo
286 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
