Please go to your motherboard manufacturer's site and search for the motherboard drivers giving your motherboard model no. The site will provide the proper drivers compatible with your motherboard.
Is the manufacturer of your motherboard Msi? Is this driver needed for the motherboard or is it needed for a separate piece of hardware that you will install? I'm assuming this is a driver that you need for your motherboard. More clarity would be much more helpful. I have found several drivers but I'm not sure exactly what you need it for or which drivers you need.
As I mentioned before, I have found several different msi pm8m drivers. If the one above isn't what you need then just provide a bit more detailed information and I'm sure I can find it for you.
You need to upgrade your memory modules to a bigger size, check your motherboard manual for supported memory speeds.
You can also look at your current memory be removeing it from the socket and see what it reads on it. Its either DDR memory or older SDRAM. I beleave your maximum memory is 3 GB
