Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Model E4401 with freezer compartment at the top. Water is leaking into the fridge. The small compartment between fridge and freezer is full of water.
SOURCE: Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Posted on Mar 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, What brand/model# is this unit? I can help
Posted on May 23, 2009
Maytag317
  • 1136 Answers
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Fridge leaks on the inside
The drain line in the freezer is blocked. It drains the water away after the defrost cycle. You will need to post your model number for me to be of more help.
Mar 30, 2012 | Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Leaking water inside refrigerator-model FRT18KC3BW2 I need know where to clean out the lines
you have to take the center bar down inside the fridge. It is the bar on top of the fridge compartment that houses the lightbulb. Unplug the fridge and unscrew the bar. There is one plug that must be unplugged, then you can pull it down. In the back is a small reservoir for water melting down from the freezer defrost, and a small tube stuck into a hole in the backof the fridge wall. pull the tube out, then flush hot hot water mixed with bleach into that hole. It will flush out anything stuck in the drain tube. If this doesnt work, you will need an external drain kit.
Nov 12, 2009 | Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Water on top of the meat/sandwich compartment in the refrigerator
it sounds like both of the defrost drain holes are blocked. the one in the fridge is accessible at the rear bottom can be cleared out by running a pipe cleaner down it. the freezer hole will need a full defrost as it may be blocked by ice.
Apr 04, 2009 | Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
77 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
