Question about Microsoft Xbox 360 Console
NO VIDEO Without any warning, my XBOX 360's video doesn't work. Audio is fine. I've changed the Audio/Video cables. The machine works perfect except NO VIDEO.Blank screen
  • goarmy432 Aug 22, 2008
    My xbox 360 av port is broken. Where can I find an av port to replace it.
    Scholar:
  • 26 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio , video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Mar 13, 2009
I've had the same issue today. I am guessing that the av port from your 360 might not be working. You might have to open it up and replace it. IDK
Posted on Jul 11, 2008
My xbox 360 will not show video. only audio. I'm using composite cables. It wont work directly to the tv, or through an RF modulator. I've even tried a new cable from the xbox to the tv. ps2 is working...
The problem is you have a broken video
line feed under the G.P.U.
The solution is to have the G.P.U. reflowed
(resoldered) .Many shop preform this type of
repair .Cost will very 50.00-80.00 . This
will produce the most durable repair.
Shop around for someone local and except
nothing less then a 90 day warranty
if you have any questions feel free to ask.
Rob
Aug 23, 2010 | Microsoft Xbox 360 Console
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
Problems with Audio and Video cable
there is a switch on the base of the cable labeled HDTV and TV, move to TV for normal cables.
Dec 06, 2009 | Microsoft Xbox 360 Console
No audio
if possible use the hdmi as a video feed and non-hdmi as a audio feed i am not sure if hdmi even carrys sound.45687d7.jpg
Jun 27, 2009 | Microsoft Xbox 360 Console
My elite has works but the video doesnt, even with light on cable
turns out after a bit of fiddling around that there is a switch on the 360 elite's VGA cable that you can switch on and off, i never knew they had these switches because it is my first tme with an elite, machine works fine though so far no freezes or glitches and im playing fallout 3. anyway for allthose that cant get video because of the cord or something make sure you check your VGA TV/HDTV switch, as i missed it too.
Jun 13, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
My PS3 will not output video.
You have gone through all the steps of the process of elimination that I would have suggested, and everything
has been eliminated as the cause of the problem except for the video card in your PS3.
Have it serviced while you still can without cost to you, if possible.
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
My XBox 360 plays video but has no sound
Put the Hd video cable in the slot and put the regular audio cables in their slot. It should work then.
Dec 16, 2008 | Microsoft Xbox 360 Console
Problems w/ 360
I had the same problem with gears of war, just take it back for a refund and get a new one. It works perfectly
May 17, 2007 | Microsoft Xbox 360 Console
Tv video blows when xbox 360 plugged to electric
make certain that you have both the XBOX and TV connected to the same AC ground.
Dec 26, 2006 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
