Question about HP Pavilion dv6110us Turion 64 X2 TL-50 1.6GHz 1GB 100GB 15.4"RG254UA PC Notebook
The life of my battery is too short..that's ;;why I always use my laptop with tha charjger on..
    Problem Solver:
  • 8 Answers
How old is the unit? On average if used only a few times a week good for 3 to 5 yrs. before no charge at all. As time goes on the charge will get to be shorter and shorter. If used every day and always plugged in 1 or 2 yrs the battery will be dead to almost dead. If the unit is not very old then quickly get it replaced via warranty from the MFG or the retailer who sold it to you. You can get a battery (Probably) from the MFG for around $40 to $75. You MAY be able to find one at www.walmart.com or www.bestbuy.com or ebay or amazon. Beware of the auctions, some bad people sell regenerated batteries only good for a few times then trash. There is a possiblity that the "Charger" is not charging completely. If that is the case then one of two problems, either the voltage is too low from the BAD charger or the "Charge cycle" is cutting off too soon. You can test for low votage easly with a simple and cheap $10/$15 multi meter. The charger should say what "Output voltage" it should have on the unit. If the charge cycle is bad, you need some one with the correct equipment to do a charger test. Walmart, best buy and others carry some generic chargers also. If you know anyone with the same charger (best if exactly same MFG, but exactly the same output different MFG should work ok also), you can use theirs to see if that fixes it, if so you need a charger.
Posted on Jan 04, 2011
How to improve battery life of Samsung AA-PB9NC6W battery
Dell is the worse laptop in this world. If anybody wants to buy a laptop, please think thousands time before you pick up NONSENSE DELL.
Jul 25, 2013 | Computers & Internet
Tip
How to optimize your Laptop Battery
Now the main problem that comes with most laptop users is the backup ThinkPad x41 battery that provides. Many of the laptops that are on the market are good enough to give you the maximum life of the battery, but this is not the case with most brands.
Here are some things or basic tips you should follow to make your Dell latitude d610 battery gives you the most time Backup.
1. First go for the clean bill of health or life of the battery. This can be done by having the software installed on your laptop that constantly monitors your Dell XPS M1710 battery and give you feedback. The Most of these programs are freeware or are incorporated with the installation disc factory. This will help you to have proper control of C1295 battery life if it can achieve the desired power or not.
2. Never attempt to manually remove and short inspiron 600m battery runs out. This will allow your battery discharge quite a while to leave the damaged battery case severe rejection. These are the most dangerous conditions and should be avoided.
3. Never discharge the Dell latitude x200 battery before connecting the power supply, because it will shorten the battery life too. Discharge completely and then charging it must always be avoided.
4. The next thing could do to save battery is to opt for the option to hibernate the laptop. This is especially useful for laptop in case of battery saving techniques.
Always follow the techniques mentioned above to make your laptop work very well give you the Backup Maximum Vostro 1500 battery life with most of the battery too.
on Oct 11, 2010 | Computers & Internet
How to improve battery life of Dell Inspiron 15R N5010 battery?
never leave your laptop on until the battery is out of charge
optimally, you can remove your battery after it's fully charged and keep your charger connected until needed.
Battery
Eventually your battery will have a short/no life indeed. Though this happens to all laptops.
Using your laptop while it is charging isn't going to damage anything. It just means that the battery will take longer to charge because you're using the laptop.
To get the most life out of the battery, fully charge it and then use it until it is empty. It's also a good idea to remove the battery when the laptop is connected to the mains supply.
All you're trying to do is extend the life of the battery. The day will come when it holds a short/no charge.
Jun 09, 2013 | Lenovo Computers & Internet
Battery life seems fairly short. How long should
In most laptops the standard idle life is around 3 - 4 hours. The drain from the internet can cut this down to between 1 - 1 and a half hours. Using games is around the same or less than what the internet takes and if your using an office application it is around 3 - 4 hours.
Using the laptop for power hungry multitasking will reduce battery life dramatically.
Regards.
Aug 18, 2009 | Acer Computers & Internet
Battery not charging.
I have the same problem at times. The life of laptop batteries is short if you are always connected to the internet. To save battery power / to increase the life of your battery overall and during each use, disable the internet when you are not using it.
Click on your "Local Area Connection Status", which is usually represented as an icon in the task bar menu at the bottom (blue bar) of your screen. Open that up and then click "disable" whenever you are not using the internet.
Unfortunately, at this point you might need a new battery though.
I hope this helps!
Sincerely, CBR2009
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Can i upgrade my video card in the amilo li 1705 laptop and also the battery life time is very very short
Yes you can buy it to nearest computer shop and bring your laptop, I believe they will recommend you the best they have that fit your amilo li laptop! You must replace the battery pack with NEW one, I once try to change the cell, but it absolutely no good. When you charge the battery, charge it when your Laptop turn-off. Better charging time is not more than 4Hours. And if you intend to use your laptop more than the battery life, or when you want to use your laptop with AC power, please remove the battery pack. Always charge the battery pack when your laptop turn-off! GoodLuck!
Jun 13, 2009 | Computers & Internet
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Short battery life
Get a replacement from Philips if it seems abnormal and you are still under warranty. 8-9 hours is normal battery life for this unit - the product specs are "ideal" - not relaistic. No way to dim this unit.
-tha mp3 doctor
May 12, 2008 | Philips SA5125/37 MP3 Player
HP Pavilion dv6110us Turion 64 X2 TL-50 1.6GHz 1GB 100GB 15.4"RG254UA PC Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
