Question about Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System
Some Headphones have an inherent hiss noise when they are connected to my wireless sennheiser EK 300 IEM G3 receiver. It seems to be a problem particularly with high-end IEMs which are highly sensitive and have very low impedance. The hiss is constant regardless of whether or not the transmitter is turned on or the volume knob is turned up.
  • iluvatar_tbb Jan 04, 2011
    It is lame that the solutions that have been paid for aren't even available to the public
  • Sennheiser Master
  • 5,603 Answers
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Posted on Jan 04, 2011
What could be wrong?
Put it in MONO mode.
You can also make a cable where the TIP and RING are wired together....
Oct 09, 2017 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
We have a problem with the lead that plugs into the receiver, and it has a shrowd over it that screws it in tight. the other end has a 90 degree angle with a mini plug into our camera, can we buyt that...
The lead is probably special. Your choice is probably to go to Sennheiser parts or make your own. The connectors are available. It sounds like the one plug is a 1/8 inch with locking ring... Those are hard to find. Contact Sennheiser to find their part number. 1-877-736-6434 ext. 1
Sep 05, 2011 | Sennheiser EK 300 IEM G3 Portable Personal...
The audio drops out. intermittently. seems to be related to the movement of the speakers head, but not conclusive. i tested the mike by plugging into a computer. it did drop out a couple times, but again ....
Wireless audio devices are subject to interference. You are a SECONDARY user of the frequency band and hence must put up with being interfered with AND should you cause interference to a licensed service, you must cease using the system. You should try other channels on the unit to see if you can find a clear channel that will not drop out. At UHF frequencies, reflections and change of positions and surroundings can cause dropouts of a system like this. Plugging into a computer is SURE to cause problems as they emit nterference at a multitude of frequencies in operation. Best to NOT have a computer operating in the area of the receiver for this system. In the back of the manual of all of these devices and computers is a note for FCC complaince regarding interference... few read it... but you should as it is the official, legal, position about RF interference between services.
Aug 14, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
Sk 100 body pack transmitter does not seem to be transmitting. Red or Bat light stays on constantly even with a new battery installed. Any quick fixes? How about schematics? Dan
Reading the instruction manual, the red LED is used for more than one thing. I suspect the unit may be either not synced with the reciever frequency chosen or in one of the mute modes. I would re-read the setup mode for this unit as the SK 100G3 is a bit more complex than many for setup.
If the light won't go off when you open the battery cover and press the button to turn it off following the procedure, then there is a problem. I would go through the COMPLETE initial setup of the unit from scratch. Schematics are non-existent for most of this and would not do you much good anyway as the circuit boards will all be surface mounted with some parts the size of a grain of salt. Also a lot of the RF will be under soldered on shield covers. Repair of these would be a factory job if they even do it. If you have ever opened a cell phone, that will be comparable.
May 08, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a...
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Mar 25, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
How do I un mute the pack
It looks like the mute function is only available from the menu... not very user friendly at all... I guess they figure the performer doesn't need to mute easily or quickly... Volume control I suspect is all that is readily availab;le at the pack to quickly mute.
Mar 13, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Disturtion in one left channel and bad quality in right channel
Make sure you are NOT overloading (clipping) due to excess signal into the transmitter end of this unit. Reduce the gain INTO the fixed unit and see if the sound improves.
Feb 23, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System Logo
272 people viewed this question
Top Sennheiser Music Experts
Michial Gueffroy
Are you a Sennheiser Music Expert? Answer questions, earn points and help others
