Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My Epson DX4050 keeps showing a paper jam and will not feed paper. there are no evident blockages and I have hoovered out the internals to clear any dust. The printer has been low usage.
Having had a similar problem, I can say that you almost certainly do have a paper jam in that the paper clear sensor is being prevented from dropping into a small recess under the paper path, by debris of some kind. You cannot see or access this sensor without dissembling the whole printer and lifting the mechanism clear of the plastic case. Once you know where all the fixing screws are, this can be done in a few minutes, but it is not a job that should be undertaken unless you have a fair degree of mechnical dexterity and are used to disconnecting very small plugs and ribbon assemblies. The secret to getting the printer apart is the removal of the control panel underneath which are more holding screws. This is done by lifting the rear of the panel with a small screw driver in the notch provided, and firmly pushing the panel to the rear of the printer. Once clear a small ribbon connector needs to be detached.
Posted on Mar 28, 2011
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson dx4050
Hello gemma almond,
Welcome, and thank you for using FixYa!
To answer your question: Your printer will need to be cleaned inside and checked for small shards of paper jammed within the paper feed path.
If you look inside of the printer, you will see small, rubber, feed tires (wheels) that pickup the paper. These tires also ensure that the paper feeds entirely through the printer. These tires can become dry and coated in clay off of the paper you use. Once they become coated, they slip on the paper.
Use a paper towel with Windex or Rubbing Alcohol to clean up these tires and an access ink you see inside of the printer.
This should fix your issue.
Have a great day!
Oct 27, 2011 | Epson Stylus Multifunction Inkjet Printer/...
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Epson stylus dx4050 paper wont feed
If the paper won't feed, it's likely that the rubber rollers are worn out.
Jan 24, 2011 | Office Equipment & Supplies
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson R220 paper feed lop sided and jammed
try putting a thick piece of card thro the paper path. this tip was given to me by an approved epson repairer. evidently paper pieces and other bits get stuck in the paper path. hope this helps , good luck
Nov 22, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
376 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
