Question about Garden
Relatively new (used once) 45cc petrol chainsaw starts fine but when you use the throttle to make the chain go round it does so slowly before cutting out. There is plenty of fuel and plenty of chain oil
    Brigadier General:
  • 4,088 Answers
Make sure the chain oil is reaching the chain. Can you turn the chain by hand fairly easily? If not, then the chain tension should be adjusted--loosen the drive cover fasteners enough to allow the bar to move up and down somewhat. Turn the chain adjuster screw CCW so that the chain can be moved by hand, but the chain should not droop from the lower bar edge. Re-tighten the cover fasteners and recheck the chain tension. If ok, try to run the saw again--it should run at full speed, 4-stroking lightly, but immediately 2-stroking when cutting. Make sure the fuel mix is fresh using a modern synthetic saw oil and shaking the container thoroughly each time just before filling the tank to prevent oil starvation. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Hope that some of this helps!
Posted on Jan 04, 2011
Throttle cable has unattached from trigger
unfortunatley there no other way to do this but you are going to have to split the case in half to get to it, My suggestion is take chain and roller off first it makes it easyier to handle, hen large dirty rag work your way round taking all screws out slowly take cae cover off, PS before you start drain petrol off store it somewhere else in a petrol can it makes it all lighter when case is split you can see trigger and cable catch unit hopefully plastic bit hasnt snapped that holds it in place if you can grab with plyers pull it back into position make sure it works ok before you put everthing back, and while you have it split in half give it a good clean at the same time and lubricate it all especially the cable onto carb bit it will operate better, hope this helps
Feb 08, 2014 | Garden
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
Chain stops when offered to the wood to cut
either a bad clutch or a bad gear in the drive head
Aug 19, 2012 | Bosch AKE 35 SDS Electric Chainsaw
How critical is the oil/petrol mix ratio in terms of starting and maintaining engine running for a McCulloch 2 stroke chain saw?
All the lubrication for the engine comes from the oil mixed with the fuel, so it is VERY important that you use good quaility two stroke oil designed to be used in a chainsaw, and mixed as per the manufacturers recommendations, if you are not too sure then run a 25.1 fuel oil mix, if the egine lacks lubrication the piston will start to scuff around the exhaust port ( the hottest part of the engine ) lose compression and become difficult or impossible to start. A quick check is to remove the muffler and take a look at the piston skirt through the open exhaust port.
Mar 06, 2012 | McCulloch Garden
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
AKE 35-19 Pro Bosch chainsaw used copule of yime worked fine this time isnt cutting chain and blades going round and tension seems to be about right
Has the chain and bar been removed-- if so, make sure the teeth are cutting toward you on the bottom run of chain. Also, make sure the chain is properly sharpened. Hope this helps!
Jun 27, 2010 | Garden
Chain turns then craps out, run hot
i assume it's a petrol driven probaby 2 stroke? if yes then you need a service on the carb & air filter if the engine is going back ok on idle speed.if it does not & goes off when you release the throttle then you may need to check the compression chamber which might have been damaged by not adding stroke oil in the petrol mixture.Hope this helps and is a 2 stroke engine...
Jun 15, 2009 | Homelite ZR10926 16 Chain Saw
Chain brake keeps tightening against bodywork
you can remove the chain brake , i have on all my saws. just be carefull if you do
Apr 28, 2009 | Garden
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
