Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Auto tune my father has a sagen free view box and the autotune keeps coming on the screen when he starts to go up and down the channels. If he saves it it keeps going back to start again if he chooses no to save then he can get back to normal channels but later the message will come back. How can he stop this from happening
  • 1 more comment
  • j_guerrasio Aug 17, 2008
    The auto tune happens every time I turn on the Sagem 612 on. I have to turn the unit on and of several times to get out of auto tune but it comes back every time I change a channel. Sagem are no help at all and I will never again buy one of their products.
  • Anonymous Aug 25, 2008
    When the television is switched on the auto scanner comes on constantly. It will eventually stop - it seems when the system warms up, but often takes 20 minutes of either switching the unit on and off or allowing the unit to auto tune. Very annoying - what is the solution?
  • jjcolst Sep 17, 2008
    i have a sagem freeview box and i also had the auto tune problem so i turned the option off but the problem i have now is the box turnes itself off for about 5 seconds and then comes back on, this seems to happen at random, today it has done it about 8 times in 20 mins! very annoying! also it is happening to 2 other people in my area with the same freeview box,,is it the box or the signal being sent to it?
Go into one of the menus setting, & say no, to found new channells. Its an option
Posted on Nov 18, 2010
So simple a solution - thanks
Posted on Aug 21, 2008
  • 3 Answers
Unfortunately tramission has been changed and certain boxes have an auto tune process as a loop. the box will work but you will have to deselect it everytime from time to time. i have the same problem with the same model. idt59g i believe. its down to the local argos with another 20 pounds to get a newer one im afraid.
i did try to turn off the auto tune option but have had no luck
Posted on Aug 18, 2008
  • smilerunited Aug 19, 2008
    result.
    i turned the auto tune loop off by............
    keying in the access code, under prefs of 1234.
    then selecting -no- when asked if u need network monitoring.
    is fine now but cant accept new channels.
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
How can i autotune my soney trinitron tv iv lost the manual
Hello
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Televison & Video
I don't have a problem I have a question. I have a rotor antenna. I am in between NYC and Phila. If I autotune in NYC and want to turn my rotor for Phila will this tv allow adding of channels without...
Most sets with digital tuners do this. The best thing to do is manually save them into memory, unless they are the same numbers, this would keep the channels tuned until you go back to them
Nov 06, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Tuning a Funai 31B-250 VCR to a Wharfedale L22T11W-A LCD TV
i have a wharfdale L22T11W-A LCD TV. have got sound but no picture, any ideas?
Dec 22, 2007 | Televison & Video
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
233 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
