Question about Iomega 1TB Desktop USB 2.0 Hard Drive
I have been using an iomega 1TB USB external hard drive to play videos on my TV (Panasonic Viera) via twonky media server I was watchin a video on my TV and half way through I got a mesage saying could not read file. Since then my PC will not recognise the external hard drive, not even in the disk manager The light on the external hard drive does come on and doesnt even make any noise Can someone help me please? I really dont want to reformat the hard drive if that is possible Thanks Steve
SOURCE: iomega external hard drive not reading
Check out following resource that may help you to find solution:
http://free-tips-tricks.blogspot.com/2009/01/hard-drive-not-recognized-found.html
Posted on May 19, 2009
  • 489 Answers
SOURCE: Hi Would you tell me how long 1tb IOMEGA hard drive formating will take?
It depends on how it is connected to the computer. A drive connected through an eSATA port should be able to format 1TB in just 1 - 2 hours depending on how loaded the system is (background processes/services, other use while it is formatting, etc). If it is connected via USB2.0, you are looking at approximately 6.3 times longer or up to 13 hours.
If you could reach and constantly maintain the theoretical maximum throughput on eSATA, it would only take about 45 minutes.
Posted on May 30, 2009
Crankstart
  • 696 Answers
SOURCE: Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
Posted on Aug 09, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
RescueTechLA
  • 2653 Answers
SOURCE: iomega 1TB Desktop USB 2.0 Hard Drive. turned it
If it's clicking then more than likely the heads have crashed. It's very expensive to fix...usually 1,500-2,700.
Hopefully you didn't have anything SUPER important on the drive. I usually recover them for 700 but I'm independent so that's why my prices are much lower.
You should still be able to return the drive to Iomega for a replacement (RMA).
Posted on Nov 23, 2009
No video
The No signal message is comming from the TV... not the media drive. The TV is not receiving a signal from drive ... Drive is the problem
May 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 1 T external that was used on Dish to save
Sure, that could work? If it saves in an industry standard format (avi, mpg, wmv), then yes. If not, then look for a converter (may need PC)
May 05, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega Select Desktop Hard Drive 1TB not decteted by pc
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Dec 17, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
No sound when plugged into TV
Me also. Have you found a solution yet?? They play fine on my laptop but only the video plays on the Trekstor
Jun 12, 2009 | Trekstor 88570 MovieStation maxi t.u 1TB...
May 30, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Playing movies from external hard drive
Hi rox09
Well you can rip your DVD to any external drive using and third party DVD ripping software ,once you do that you will get a AVI,MPEG and any common fomats your DVD player supports
Inorder to play those files in your DVD player ,you need the check whether your DVD has a USB input port or else if you laptop or computer has a S-video out put and your TV has S-Video input ;you can play directly from your laptop/computer to the TV using a S-video Cable which is available in any Computer shop.
I hope this helps
VJ
Mar 15, 2009 | ASUS Eee PC 900 Notebook
1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
Nov 12, 2008 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
57 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
