Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Transform Duo Stick into an SD card ~ Possible?
I want to by a new camera but I want to still be able to use my old memory card. I was just going to buy the same type of camera but bestbuy didn't have that model anymore. My memory card is a Sony Duo Stick but the new camera I wish to buy uses an SD. How can I transform my Duo Stick into an SD. Is that even possible?
    Scholar:
  • 78 Answers
Hi Qwin,
Although you cannot directly use your Duo Stick in a camera which supports SD, you are able to purchase a memory card reader to support both formats. This means that you can transfer data from the Duo Stick or the SD onto your computer, and then put the data onto the other card.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 09, 2008
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
I need a sd card and cable for sony f 717
Your Sony uses a memory stick called Sony Memory Stick Pro which they don't make any more, it was replaced with a smaller card called Sony Memory Stick Pro Duo, go to ebay and buy a adapter called Sony Memory Stick Pro Adapter it is sliver in color with blue color at the end. Once you get ahold of that adapter, you can now buy the new smaller card called Sony Memory Stick Pro Duo and insert it to that adapter, then slide the adapter with the new smaller card into your camera.
I have several older Sony digital camera that I converted to use the newer Sony Memory Stick Pro Duo cards, it works great ! I checked your Sony model on Ebay and you have to scroll down a bit to see those adapters I just mentioned, some sell with the adapter and the newer memory stick already included in the price.
Oct 06, 2014 | Sony Cameras
Do i need a sd card o make camera work
You can't make the DCR-HC42 work with an SD card. This camcorder uses DV tapes, or Memory Stick Duo or Memory Stick Pro Duo memory cards.
Jun 06, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
My hp officejet 7210 all in one will not read my SDHC memory card for my new Panasonic camera. Why? Should I purchase just a SD memory card? Will that work?? Thanks
Purchasing an SD card might be better. Just for the fact that when your printer was manufactured the technology for SDHC cards were still not incorporated in your printer.
Feb 06, 2011 | HP Office Equipment & Supplies
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Ive bought a new memory card for my pentax optic e10 camera when ive inserted it it is reading memory card error what can i do
This camera takes an SD (secure digital) memory card according to amazon and google. Looks like your using a Sony Memory Stick Pro Duo which would not be compatible.
Try using an SD card.
Jun 13, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Can you use the same memory chip for different camera?
If you mean memory card, Then you will have your old pictures :]
Feb 04, 2009 | Sony Cyber-shot DSC-S780 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
