My epson sx215 has error message W-11 'ink cartridges not recognised' on it. They are the correct ones and did work before I went away for 3 weeks. Have tried cleaning them and know they don't need replacing. Help!
cns assoc
  • 677 Answers
SOURCE: Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 05, 2010
Testimonial: "Thanks for your help. I have started using generic cartridges as I did with my Canon for years. Your help is much appreciated."
SOURCE: how do i change the
press: INDEX SHEET and SCAN both at the same time, use two fingers if possible.
Your epson monitor Screen should show: NOZZLE CHECK and below that a left and right arrow with 1/6 between them. using the right hand arrow key just below the monitor, scroll through to item 4. then press the green start key to get the carriage ink holder to move into change position.proceed .
Posted on Jan 21, 2011
Grubhead
  • 5259 Answers
SOURCE: Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Posted on Apr 12, 2009
  • 6 Answers
SOURCE: Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Posted on Apr 15, 2009
SOURCE: epson sx405 doesnt recognise ink
I CHANGED MY INK CARTIDGE IN EPSON SX405,SHOWING INK CARTIDGE CANOT BE RECOGNIZED
Posted on Aug 03, 2009
It won't recognise my ink cartridged
Reset unit to factory defaults. Epson will tell you what to do.
Sep 15, 2017 | Epson Stylus NX200 Printer
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
Jan 07, 2011 | Epson Office Equipment & Supplies
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Error message saying cannot recognise ink cartridges
hello
Double check to see if the cartridges that came with your machine are really the correct ones. And if they are then make sure they are snapped in securely as they must make a solid contact to read the cartridges. Also make sure the drivers and software are properly installed onto your computer.Also make sure that the tape that is usually on the cartridges to protect them in handling and shipping are removed before installation.
regards
Jul 13, 2009 | Epson Stylus NX400 InkJet Printer
Epson s20 genuin ink not recognised
I think the problem is in your windows, try to reinstall your windows. I suggest, don't reset the original chip, cause it's damage the chip.
May 29, 2009 | Epson Stylus S20 InkJet Photo Printer...
Apr 15, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
2,711 people viewed this question
jasbo
jasbo
