Question about Roland HandSonic 10 Percussion Controller
Hello my handsonic 10 has lost volume output on all the pads on kit selection 1 on the (undo) latin perc all other selections onwards to 64 are all ok and have no volume loss at all can you help thanks peter
  • Roland Master
  • 5,603 Answers
Since the electronics and sensors are ALL the same for ALL the voices, this has to be a setting within the unit. Look for a sensitivity setting in your manual for the unit. Some of these also have a setting for use with sticks that VASTLY affects the sensitivity.
Pay particular attention to "Kit Volume" on page 22 of your user's manual. This affects the volume for different "Kits".
Posted on Jan 04, 2011
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Is there a way to replace the settings key pads?
These pads can be replaced ( providing Casio still have spare parts ) There are a lot of screws to undo to get inside the keyboard, then remove any PCB above the pad, replace and reassemble.
or
Contact your nearest Casio service centre
Oct 29, 2015 | Casio Music
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
May 08, 2011 | Alesis DM6 Electronic Drum Set
My Roland will not power up at all. Not sure if it is the power supply or the handsonic itself.
Test the power supply with a meter. It should be 9 volts DC and it rated at 2 to 2.5 amps (2000 to 2500 ma)
Jan 20, 2011 | Roland HandSonic 10 Percussion Controller
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Hello sir i need a spare rubber for my HAND SONIC PAD HPD 15 can u please guide me for the same i shall be thank Full to u.
Try going to this link, chose your country and look under support or local dealers; http://www.roland.com/index.html You can also try this link; http://www.sweetwater.com/store/detail/HPD15/ Call their toll free number or email them to talk to a tech for advice.
Jun 22, 2010 | Roland HandSonic 10 Percussion Controller
Upper rubber of hand sonic
This you would have to get from Roland. Find the Roland site and "support" and contact them.
http://www.rolandus.com/support/
Contact them by email initially and find part number to order.
Apr 27, 2010 | Roland HandSonic 10 Percussion Controller
Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Roland HandSonic 10 Percussion Controller Logo
239 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
