I have a Baxi 80E combi instant and i am experiencing problems with the hot water function. For last week or so when operating hot tap the water has initially run hot then keeps going cold and will come back on when tap is opened fully. The hot water has now stopped working completely even if opened fully and the hot water light on unit does not illuminate as it used to. I was advised by a friend to try changing the DHW flow microswitch on the diverter valve and have also changed the diaphragm as a precaution but i am still unable to get hot water. Could you recomend what my next course of action may be?
  • Heating & Co... Master
  • 3,238 Answers
Sounds like the diverter valve is stuck
Posted on Apr 14, 2017
SOURCE: baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Posted on Nov 02, 2008
  • 16 Answers
SOURCE: Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Posted on Jul 10, 2009
mrhotandcold
  • 248 Answers
SOURCE: no hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Posted on Oct 12, 2009
SOURCE: water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Posted on Jan 14, 2010
  • 6 Answers
SOURCE: just changed my bathtub/shower valves water flow changes
Try to make sure there is no obstruction in the manifold (housing).
Posted on Sep 19, 2010
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
No hot water...can any1 help i have a baxi combi 80e
Oct 12, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Baxi 80e - water pressure too high
water will stop coming out of the once pressure drops . it will act the same and water will flow out of pipe the same .
Jul 25, 2017 | Combi Centre DX - Mango
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
