Question about Ebac BD150 Dehumidifier
We currently have a machine which is switiching itself off after a short period of use. The water tank is not full and there is a consistant power supply going to the machine. Any ideas what could be causing this?
Is it possible to buy a portable dehumidifier which will automatically restart and function after a temporary power outage? What do you ask for?
Hello William, thank you for your post!
I understand that you would like to have a dehumidifier that restarts after a power outage. I have reviewed the available models for Frigidaire and show that feature is not available. You may want to speak with additional manufacturers for that feature. I hope this information is helpful to you. -Matt
Mar 20, 2016 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
My unit stopped working after less than 1 year . It will occ start up dor a few secs and then stop again??
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck
Aug 15, 2010 | LG LHD45EL Dehumidifier
I have an LG LHD65EBL dehumidifier. When I checked on it today the unit was not running and the display read "CH 01". I tried cleaning the filter, cleaning the front of the coils, and resetting the unit by...
Hi
Take care.
Aug 15, 2010 | LG LHD65EBL Dehumidifier
My dehumidfier runs for about a min and then stops running
If you've emptied the tank and the unit still stops running after a min, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 12, 2010 | Goldstar DH304 Dehumidifier
My dehumidifer kr923317 283w will not come on it just beeps
Good luck.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
My dehumidifyer won't continuously run
HI,
Take care
Aug 11, 2010 | Whirlpool Dehumidifiers
My DeLonghi DEM10 wont power on any more - like fuse gone
Sep 03, 2009 | DeLonghi Dehumidifiers
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Bogus 'Full' warning
or you could just tape the bucket in place. when the compressor kicks in the unit vibrates which might be shacking the bucket loose to the point that it doesn't make contact with the switch.
Jul 02, 2006 | Maytag M7DH45B2A Dehumidifier
Ebac BD150 Dehumidifier Logo
56 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
