Question about Car Audio & Video
Re: yea i know the speakers work for sure....my wife was driving the truck and they decided to work for about 20 min and then out of nowhere it went silent again...i dont have any amp or anything jus a basic stereo...
    Champion:
  • 217 Answers
The ground wire for the stereo may be loose then. I've had that same problem in the past... 2-3 times. It'll connect enough to run the stereo, but the power will be too weak to power the sound to the speakers. There might also be an in-line fuse behind the stereo deck or one on the back of it. Let me know if you find anything :)
Posted on Jul 10, 2008
My headlights only turn on when they want. They are brand new as of late last year. PLEASE HELP!
These cars were designed to have daytime running lights, that can turn off with the ebrake being pulled, so perhaps whatever wiring mechanism that enable that, is failing.
Mar 21, 2017 | 1999 Oldsmobile Aurora
Transmission in 2002 cadillac deville stoped working after 20 min drive i shut car off and restarted and it worked
Get your Automatic Transmission Fluid (ATF) checked, it could be old or low. May be time for Transmission flush, too.
GL,
Td
Oct 03, 2012 | Cars & Trucks
I bypassed the heater core and now car is over heating
It could be that it took that long for the thermostat to open up. You could try using a longer hose to make sure it flows, but I would want to know if the radiator fan is working too. It does not need the heater itself to cool the engine.
Sep 28, 2012 | 1995 Honda Civic
I have a SONY VAIO VGB-140E. Using the external speakers, the sound is working. The internal speakers sound is suddenly stop working. I did re-install the sound drive and also did a system restore but no...
go into your sound driver options and locate the speakers you are trying to use, weather it be external or otherwise. Make sure the volume is up (i know obvious but still)
rate yea?
Jul 08, 2011 | Sony VAIO VGN-NS140E/S Notebook PC
Keeps shutting down after 20 mins of driving alrready fuel pump could it be the relay sensor dealership cant figure out
Yea right what dealer wont tell i will tell, the 2.4 and 2.7 There is a TSB for this. They are to inspect for faulty CMP signal (cam sensor signal) which causes engine to idle rough or lack of power. they are to try shaking sensor connector to see if it affects operation and inspect for electrical connection for looseness and poor amle to female terminal pin fit. let me know if I help you out
Apr 30, 2011 | 2007 Kia Rondo LX V6
We had a thunder storm on Thursday lightning struck the dish and both t.v.s went off. my wife called dish they came and change everything,know mt t.v in the living room works has volume my t.v. in the bed...
. Make sure that you don't have mute on, and make sure your TV speakers are turn on. Go to menu and see if there is a way to turn your internal speakers on. If you can't fine anything , then your audio processor could be locked up, and if you unplug your TV for 30 MIN. it will reset the processor back to normal. Good luck and have a nice Day.
Oct 16, 2010 | Protron PLTV-37 37 in. LCD Television
I installed new speakers to my Honda after installing them they stopped working after 20 min of using them.They came back on after 10 min then went out again and did the same when I installed my new stereo...
They were shorting on the internals of the car door. Put some electrical tape over the connections to make sure this doesn't happen - it can be very unhealthy for your amp.
Jan 07, 2010 | Rockford Fosgate Punch® P2D412 Car...
FRONT SPEAKERS HAVE NO AUDIO AND REAR SPEAKERS IMEDIATELY FADE
check all your wires in the front speakers and make sure there coverd
Dec 06, 2008 | 1992 Mercedes-Benz 190
Pc stuck in sleep mode...
You will need to replace the hard drive which has any version of windows operating system, or you will have to re-install windows xp on that computer. Assuming if the computer has a green light and monitor has an orange light. I've encountered this problem where I work at.
Nov 06, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
