Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing
scanning resolution.
The higher the scanning resolution is, the more
precise the scanned images are represented, however, the file size gets
larger.
The scanning resolution can be changed before scanning
photos.
Note:
When the scanning resolution is doubled, the image
data size will be quadrupled.
When the data size is large, the throughput speed may
slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo:
The following is explained using MP Navigator 3.0
procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents
(Platen) on the Scan/Import tab.
- The window you see
varies according to the printer model.
2. When the Photos/Documents (Platen) window is
displayed, click Specify.
3. When the Scan Settings window is displayed,
select the resolution in Scanning Resolution.
If necessary, set other
items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click
Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner
Driver on the Scan/Import tab.
2. Change the resolution.
According to your
purpose, set the resolution in Simple Mode with ease, or in Advanced
Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the
Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the
preset resolution, or enter the number from 25 to 19200 to specify your
favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Is it about Twain_32?
Give me the exact error message if possible attach the screenshot
