Question about Xerox Phaser 6100/DN Laser Printer
Fitted new imaging unit but counter did not reset
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
  • 110 Answers
SOURCE: counter wont reset after installing new imaging unit
One of the main chips has stoped working on the engine control board. So it does not blow up the fuse inside the Image unit and therefore can't reset the counter. Try changing the engine control board. part number is .. 116-1538-00
http://www.iteminconline.com/items.asp?Cc=7300P&ItemMoveby=0&Nbm=ZMD128%2FA&Pbm=119%2D6401%2D00&iTpStatus=0&Tp=&sTitle=&FromNav=False
Posted on Oct 02, 2009
  • 1121 Answers
SOURCE: c350 bizhub image unit counter won't reset after
using a post:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
thanks for krishmaqvan
Posted on Dec 29, 2009
furiacega
  • 548 Answers
SOURCE: How to Reset counter of Image Unit CLP 300
Well it is a tricky operation, because you have to put some screws off the back of the printer and make a short circuit. The safest way to do this is to take to a professional workshop.
Posted on Apr 07, 2010
  • 3 Answers
SOURCE: Clx2160 invalid imaging unit, How do
Try a factory reset by pressing menu->ID Copy->Left->Right->Menu->Black Start consecutively. p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 9.7px Helvetica}
Posted on Nov 23, 2010
Reset drum counter 130f
Do not reset drum counter unless the drum has been replaced.. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub 283 error reset devloper value
You must need replaced a old developer.Before instaled a new reset developer counter or image unit counter in special parts counter.
Dec 21, 2013 | Konica Minolta Office Equipment & Supplies
The imaging unit need to be changed but it was just changed
When a new Imaging Unit is installed there is a fuse contained within the new unit that blows and resets an electronic counter in the machine. If you installed or had installed a new imaging unit, then the only way the machine would be asking for a new imaging unit now is if either you ran about 70,000 copies or somehow the new unit did not reset the counter. I have never heard of one not resetting the counter as at the same time the counter is reset, the machine initializes the new unit and adjust the ATDC ratio. If this had not occured the mixture of toner to starter (developer) would not be correct and the copies would either become light (undertoned) or have a dark background (overtoned).
If you had the new unit installed then I would contact the service company that installed it and ask for a replacment. If you installed it yourself then there may not be much you can do. You can order a new reset fuse for around $5 and replace the fuse in your imaging unit so the machine thinks there has been another unit installed. precisionroller.com has them. Just go there and enter "Di350 fuse" in the search box. In case you were not aware, Your NEC is made by Minolta and is indenticle to a Di350/351.
Those would be your options.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 17, 2010 | NEC IT3510 Copier
I am getting an error, please chnage imaging unit and My printer is unable to print any document since this morning . It is taking time as weelll
Printer needs a new drum unit (imaging unit). Replacing it will either automatically clear the error (and reset the counter for the imaging unit), or there will be a set of reset instructions provided with the new unit.
Feb 03, 2010 | Minolta - DI200F Printer
Counter wont reset after installing new imaging unit
Sep 18, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
How to reset the copier after installing the new imageing unit c350
Normally it has no need for reseting.
In the moment you put the new image unit it resets the counter life, although you can reset by holding down the trouble reset button and in the screen you will see trouble reset.
touch it and switch in and off the machine with the main power button.
May 15, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Xerox Phaser 6100/DN Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
