Question about Brother IntelliFAX 1250M Fax
Brother Intellifax 1250 blue lock levers
Hi there. Do you have any Brother Intellifax 1250 blue lock levers available? I have two machines and both have the right side broken. If I wanted to buy two complete sets of two (i.e., 2 lefts and 2 rights) what would that run me? My shipping address is 1236 Cornerstone Blvd, Unit 274, Downingtown, PA, 19335. My email address is ftav4444 at yahoo dot com. Thanks.
  • Anonymous Sep 05, 2008
    I have the same problem. The right blue lever is broken. Where do i get a new one and how is it installed?
    New Friend:
  • 120 Answers
$15 each lever. Lawrence
Posted on Jul 28, 2008
Need repair manual and schematics for intellifax 1250 machine
we do not have the repair manuals for this machine, only the user manual is avail.
Oct 25, 2010 | Office Equipment & Supplies
I have a Brother Intellifax 1250, getting error 81... Other than older than dirt and throw away, can anyone tell me what that error code is?
Well the scanner is gone there is no parts . Brother dose not support that old of unit any more. (sorry) spend some money and get you a new unit. They were a good machine in there day.
Jul 21, 2010 | Brother IntelliFAX 1250M Fax
How to change the drum of my brother intellifax 2830
open the front cover of the machine, remove the toner. the drum will come out with the toner, it's the tray holding it. press the blue lever to seperate them. you can just slide on the new one.
Mar 02, 2010 | Brother IntelliFax-2820 Laser Fax
Only half of incoming faxes are printed.
Is this a machine that uses a big, black roll of thermal donor film? The Fax 1250 and several other models have a common problem where the left side prints perfectly, but fades to blank on the right (or the opposite). When you replace that donor film cartridge, you open the top and push a blue lever back on each side to raise the print element assembly.If one of those levers cracks, it will still hold down the head and look normal, but it won't hold it tightly enough the paper to to print on that side.
For models Fax-1150/1250M/1350M/1450MC/1550MC
the parts are
Left (as viewed from the front):UF6085001
Right: UF6087001
One or two screws hold the metal plate on top, then the levers are held on by the springs.
Aug 05, 2009 | Brother Office Equipment & Supplies
"Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Jun 17, 2009 | Brother IntelliFax-2820 Laser Fax
Brother intellifax 2820.Replaced toner cart tn350.
Remove drum unit. in front of the toner cart. there is ether a green or blue slide lever. move the slide 10-15 times back and forth. make sher the slide is all the way over to one side. reinstall drum & make a copie. hope this works.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Print only on rigth side. I know it the blue lever. Where can I get parts
I have the same problem with my 1950MC. When I examined the blue lever carefully on the right side of the machine I found that the plastic lever was cracked at its thinnest point. Thus when both levers are locked down that one was not holding the print head tightly enough to print that side of the paper. If I held the print head down manually, the copy printed fine. So if you have this problem, check the blue levers for cracks. The levers are easy to remove and should not cost very much. I recommend that you replace both left and right levers. These plastic parts cannot stand up to very much use without cracking.
Jun 22, 2008 | Brother MFC 1950MC Printer
Fax printing problem
The blue release lever that holds the ribbon cartride may be cracked or broken. The crack may be so fine, that it's not easy to see, so look carefully. Even the slightest crack will cause the ribbon cartridge to fit loosely enough so that the roller is not touching the paper. Whatever side is not printing, that's the lever that you should look at. That's what happened to mine. I was ready to buy a new machine, until I found that solution. To test it, I tried to copy something while pushing down on that side of the ribbon cartridge, and it printed fine--the whole page. I looked more closely at the lever, and found the crack.
Jun 10, 2008 | Brother IntelliFAX 1250M Fax
Printing problem
One of the blue locking levers is broke. the side that is light is the side the locking lever is n.g. open the top like you want to change the film. there are 2 locking levers. right and left. They are different. if you look close you will see a split in the plastic when it locks down. It is not holding down on one side. I think I have the locking levers. One small screw removes the top plate and you can change them. Lawrence
Aug 16, 2007 | Brother IntelliFAX 1250M Fax
119 people viewed this question
James Cagle
James Cagle
Jim Keysor
