Question about HP OfficeJet 4255 All-In-One InkJet Printer
PRINTING SPEED SLOW. PAPER jam - HP OfficeJet 4255 All-In-One InkJet Printer
    Scholar:
  • 111 Answers
You need to clean the rollers,
Look at the back of the printer open the back and you will see rollers there , check whether they are moving freely or not. try to clean them with damp cloth make sure that its unplugged from the power outlet while you are doing it
Posted on Jan 04, 2011
3 Suggested Answers
SOURCE: What to do if printer is printing slow after a
Open up printer to see if bits of paper are still wedged into tiny spots, if found remove same. Check for alignments of internal parts then close up printer.
Disconnect/reconnect power supply
Delete job and resend job.
Posted on Apr 08, 2010
  • 21 Answers
SOURCE: HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Posted on May 09, 2010
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Excel sheet not print for hp laserjet p1007
please do the following check if the printer is on and is blinking green will printing if its blinking red then it means there is a problem,if its green and its not printing the following might be the problem
  • your print server is slow Add more RAM to increase its printing speed
  • your print drivers are not well reinstall them
if its blinking red then check the following
  • paper jam-paper stuck in the computer
  • print ctaridge not placed properly
Jan 19, 2015 | HP Hewlett Packard LaserJet P1005 Printer
Ricoh 6123 b copy printer paper jamming in feeding section frequently.
store paper in dry conditions. check any rollers for being worn out
Jan 03, 2015 | Ricoh Office Equipment & Supplies
Feb 15, 2010 | HP LaserJet P3005n Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Printing is very, very slow
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Mar 03, 2009 | HP - HP Photosmart 8250 printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Slower printing speed
Multiple sheet feeding in any printer can mean many things. Paper roller blockages and jams, wrong paper for printer, too much paper in. Make sure you check right down the back and inside the unit for anh small blocks. This can then cause errors in the printer itself. As it is now printing but slow, the paer issue could be resoved but you may now have driver errors or pc issues. Are you getting any flashing LED lights. Have you checked to see if device is showing errors or functioning correctly. Go to start menu, control panel, performance/main, system, devices, scroll down to your printer, are there any yellow exclamations? Does it say it is working ok?
Aug 10, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
