Question about Microwave Ovens
Pf code flashing on oven - Microwave Ovens
  • Microwave Ovens Master
  • 3,740 Answers
PF = Power failure.
Usually all you have to do is press stop / cancel, then Clock then CLOCK again. After the time is set your microwave should work normally again.
If this does NOT correct your problem I need a complete model number in any future responses.
Thanks for choosing FixYa.
Kelly
Posted on Jan 04, 2011
Is light supposed to come on when door is opened?
Yes the light comes on when the door is opened and when the microwave is active! The PF code indicates a Power Failure, press clear or cancel to reset or unplug for a few minutes and re plug!
Nov 08, 2014 | Microwave Ovens
GE microwave with error code of PF and won't heat anything up
The "PF" on any appliance indicates a power failure. So if you lost power in a recent storm, this would cause your problem. Pressing the cancel button should clear up your problem, and put you back in business. If not, unplug the unit, plug it back in and try the cancel button again. If trouble persists, your board is probably at fault.
Jul 20, 2014 | GE Microwave Ovens
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Sharp R-209HK Microwave Oven
What does PF mean on my LG washing machine?
According to lg PF code signifies that your washing machine has experienced a power failure,
Mar 17, 2011 | LG Microwave Ovens
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
186 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
