I have bought a Best Coonectivity USB 2.0 Cardbus for my Dell Inspiron 8200 so I can have additional 2 additional ports and also have a 2.O high speed USB facilty . When I connect an external DVDRW/CD drive ,or my my satnav to download updates to the card bus my genius 110 optical mouse freezes , as also does my microsoft keyboard.Unplugging the devices does not unfreeze the mouse or key board , I have to swith the pc off How do I overcome this problem?
  • 314 Answers
Best drivers
Instructions
  1. Clean the DVD drive completely. Remove the dust and dirt from the laser using a CD/DVD cleaner disk. In many cases, this simple task will resolve the DVD failure.
  2. Check your DVD drive settings. Make sure that you're not using "compatibility mode" drivers, and that performance settings are properly set.
  3. Update the driver for your DVD Drive Click "Start," "Control Panel," "System," "Hardware" and then "Device Manager." Highlight your DVD drive, click "Action" and then "Update Driver."
  4. Run troubleshooting software. There are several DVD testing software packages, such as SANDRA and CheckIt. These applications may be able to identify the exact problem with the DVD drive.
  5. Look for physical problems with the DVD drive. For example, if the drive is vibrating or making strange noises, you can check to see if the DVD drive is loose in the chassis. Another common physical problem is a jammed tray, which may be fixed by inserting a straightened paper clip into the hole next to the tray door.
please comment on these solution by saying how helpful.
Posted on Jan 04, 2011
  • adelani muazudeen Jan 04, 2011
    Instructions
      Windows Vista
    1. Open
      "Start" and click "All Programs." Select "Windows Update." Type in your
      account password if the operating system prompts you for it.
    2. Click
      the "Check For Updates" link. Select "View Available Updates" and check
      to see if any drivers are listed for your laptop. Click the specific
      driver you want to update.
    3. Click
      "Install." Restart the laptop after the installation finishes and see
      if the driver problem is resolved. Return to the "Start" menu and click
      "Control Panel" if the problem persists.
    4. Select "System and Maintenance." Click the "Update Device Driver" link underneath the "Device Manager" heading.
    5. Find
      the specific device that isn't working properly in the list of
      available devices. Right-click the device and choose "Update Device
      Driver."
    6. Windows XP
    7. Right-click the "My Computer" icon on the desktop. Click "Manage," then select "Device Manager."
    8. Scroll through the list of hardware devices being used by your laptop. Find the specific device that is having a driver problem.
    9. Right-click the name of the device and choose "Properties." Navigate to the "Driver" tab.
    10. Click "Update Driver." Select "OK" to repair the driver problem.
    11. these comment is all about drivers and laptop so the solution good for your question so ,that all i have for now.
Is there an adaptor available in order to use a Dell PD01S with a standard USB? I have an IBM laptop I want to use this with...
Your best bet will be to get a "USB 2.0 CardBus Adapter". This will give you an extra USB port to use. It is a bad idea to go from 2 USBs to 1 in this instance. Below I provided a link to ebay for some options
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=USB+2.0+CardBus+Adapter&_sacat=See-All-Categories
May 04, 2011 | Dell PD01S (PD01S) External Floppy Drive
Does the dell 8200 have usb ports? if so, where?
It is at the back of the computer and it may also have addition USB port at the front panel behind a cover.
Feb 03, 2011 | Dell Dimension 8200 PC Desktop
I have a dell inspiron 2650 aproximatly 2002. I have tried to install a dynex usb 2.0 cardbus adapter unsuccessfully and it slows down then shuts down my laptop. the instructions say to just put the card...
Hi there! The Cardbus adapter should come with a cd installer/driver. The driver should be compatible with the operating system you're running on your com[puter.
Try to install the driver first adn then when prompted, insert the cardbus adapter.
Hope it works!
^_^
Jun 03, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Wrong manual advertised
Here are the service manual and owner's manual
http://support.dell.com/support/edocs/systems/ins8200/en/sm_en/index.htm
http://support.dell.com/support/edocs/systems/ins8200/en/1H018bk3.pdf
Feb 10, 2010 | Dell Inspiron 8200 Notebook
SIIG Hi-speed USB 4-port cardBus - iphone/flashdrive problems
Remove your device from the device manager and reboot unit.
Restart and reload device drivers.
Make sure the driver are for xp pro
Nov 14, 2009 | Electronics - Others
Dell inspiron 8200
Yes buy a PCMCIA adapter card. You can search yourself or just buy one here
Good luck and remember please rate this post
Dec 31, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | Computers & Internet
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Problem plugging adaptor into cardbus usb port
sounds like its not supported by the NEC Cardbus
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
