Question about Canon PIXMA MP150 All-In-One InkJet Printer
Computer is sayinng the printer is off-line. I
Computer is sayinng the printer is off-line. I have checked all the connections but they are fine! Pl can you help?
    Scholar:
  • 151 Answers
Depending on your operating system you can try the following:
go to your control pannel, find your printers, RIGHT click on the icon for your printer and see if the "use printer online" option is availible.
if this option is not availible, or does not work...you may need to download the latest drivers fro. the Cannon website. (I am only assuming that you installed the drivers from the CD that came with it)
again, if this does not work either....check that the printer IS recieving power and the indicator lights come on(I assume you did this already)
as a last resort, if none of the above work at all....I would bring the printer back to the place of purchase and see if you can exchange for another. Sometimes you do get a lemon.
Posted on Jan 04, 2011
How do i get my printer to work when it says "printer not responding"
Dear
Pl. change the usb port (connect the USB data cable to the back side port of the PC). Make the printer on-line and test.
Pl. do check your antivirus.
Thanks.
Dec 04, 2014 | Office Equipment & Supplies
HP Officejet 6500 no longer hears the dialtone. The line works fine with a regular phone, but not the printer. Up until a couple of days ago, it worked fine. The printer says the line is in use (wh
Usually on hook telephone line voltage around 40V DC +/- depends on exchange, voltage will drops below 12VDC if its half hook..You will get engage tone/usage tone if voltage drops less than 12V, in this condition you wont get any incoming calls.
You need to open the printer formatter to locate the modem where telephone line inserted..
Let understand why this malfunction happens..
The ring voltage between the line is +120V AC, but it should not exceed more than 200V.. To protect the circuit, line will guarded by component called "VARISTOR". The Varistor will burns if voltage reaches specified or more voltage across it.. Once varistor burns U will get engage tone always... Basic multimeter is enough to check the varistor, put multimeter in diode mode, test both ends of varistor, it should not show zero value or beeping. Some times it may burn, blast or bulge. Remove the faulty component from the circuit with the help of soldering iron, connect the line & verify, if line is good replace with same rating of component.. Chk for the ring & dial tone...
Req tools: Multimeeter, soldering iron, little paste & Led, screw driver set for opening the printer..
Depends on design varistor may fix accordingly which we need to find out the location.. But its always fixed between line in path. pl see the attached sample diagram.
if you are non technical pl don,t try it...Best of luck.. 6f4a7950-5cc9-42c6-bb47-b2ba2007add0.jpg 21aa8d50-de72-49d9-a692-6c813c2c0768.jpgEx: Varistor ac224650-2c77-4de1-934f-929cbd6f0d15.jpg Damaged/burnt varistor
Apr 01, 2014 | HP Officejet 6500A Plus Wireless...
Hp image zone help
You may find your answer here :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03081973&cc=us&dlc=en&lc=en&product=1153754&tmp_track_link=ot_search
Feb 17, 2014 | HP Computers & Internet
Power supply problem
The easy and cheaper way to use voltmeter and check el. elements, fuses, varistors, colis,... if not send the message and I will try to find the supply
Apr 30, 2010 | Konica Minolta Laser Printer
Problem with my HP LJ 1020 is when i print through network
LJ1020 is not a network printer. I think this printer connected to a local computer which may called as print server. and the printer connected to all other computers through this computer. if it so, Pl. let me know that whether the print finish its process when it was given from the Print server. if not, Pl uninstall the driver from the print server and reinstall.
Aug 26, 2009 | HP LaserJet 1020 Printer
I want to downlaod the Hp LaserJet 1018 driver
Dear User,
Pl open my networkplace in your computer after going(via network) to that pc connected to printer.
when open that pc pl see printer and right click on printer to press connect.
printer is connected to your computer.
Regards,
Ravindra Shah
Jun 29, 2009 | HP LaserJet 1018 Printer
Hello, My Epson R1800 is showing 2 red lights and I need to fix the problem but there is no communication between the printer and the computer - any advise on what to do? Your help is appreciated Many...
Dear User,
Pl check your printer driver installed correctly or not if not pl install with its cd.
printer and computer not communication by cable problem or computer or printer three types of cause.
pl printer install with another pc and check it.
Regards,
Ravindra shah
Jun 29, 2009 | Epson Stylus Photo R1800 InkJet Printer
My printer epson dot matrics lx 300 + writes first 2 lines correctly but next lines in italic. what is the solution?
DEAR,
PL CHECK YOUR PRINTER HEAD IS STUCKING OR NOT.
1ST FILL OIL IN PRINTER ROAD (HEAD MOVES ON)
2ND CHECK YOUR PRINTER HEAD BLOCK BUSH IS PROPER SITTING OR NOT.
Feb 26, 2009 | Epson LX-300 Matrix Printer
Canon mx310
Did you connected the line at "L" slot or try with your phone operator to check your tel. lines
Jul 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
29 people viewed this question
old marine
old marine
