Question about MTX Bon Musica 16" Viola Shoulder Rest
The spongy bit has come off. Can we fix it? - MTX Bon Musica 16" Viola Shoulder Rest
  • MTX Master
  • 5,603 Answers
Yes, assuming the spongy part has not deteriorated, get some contact cement and follow the directions. Coat the metal and the spongy with a thin coat of the cement. Let dry till tacky and then carefully press the spongy into place. Make sure you get it straight as once the glue touches it grabs. Start one end and then roll it down into place.
If the spngy part has deteriorated, find new material and apply as above.
Posted on Jan 04, 2011
I have an ibanez tone blaster,the lights and all come on but no sound is made. Can anyone tell me what might be the problem?
Some hopefully easy fixes : Input jack could be the problem, or connection from the amp to the speaker. Does the speaker hum a bit with the volume up almost all of the way without anything plugged into the unit? If not, check the connection from speaker to amp.
If it does hum slightly when u crank the volume, check your input jack -- it might be jacked up (pardon the pun) and you can fix that easily by soldering in a new one.
Jun 11, 2016 | Ibanez Music
I turn on my XP 50 Roland I can play for a little bit but then it turns off on off on need help to fix it
if your saying the power goes on/off allot then its got to be your power cord or connector in the back , these do have a hard life as these get moved around a bit , its gonna take a pro repair to replace the power connector-but you can buy new cords for them , try to wiggle it to confirm that's it , but if your display just goes on off , this is a software problem as most likely a error in reading the drive
May 12, 2016 | Roland Music
Filter Knob and Buttons move from left to right
If you pull the knobs off, you will find lock nuts under them. You could tighten them up. See if the knobs have set screws on them to lock them in place before pulling them off. On Allen & Heath, I don't think they do but, just in case.
Mar 21, 2014 | Allen & Heath Xone:92 DJ Mixer
The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
Sep 24, 2012 | Alesis DM7 USB Electronic Drum Kit
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Feb 21, 2012 | Music
The amp was working fine and than just stoped , it wont turn on and all power is working.
The most likely problem in this instance is damage to the power supply, probably caused by a power surge. The second most likely cause is damage to the power cord. If you can take it to a shop that has similar amps on display, you can probably test it on one of there power cords. If the power supply is damaged, it will be a bit more challenging. At this point, if you know a bit about circuit boards and soldering, you might be able to fix it. If not, you will probably have to pay someone, or simply replace the amp.
Mar 14, 2011 | Line 6 Spider Iii 75 Guitar Combo...
My pitch slider has snaped off my cdj gemini 203's ? how do i fix it ?
The fader slider will have to be replaced. It is a bit of work, however finding the exact replacement often is hard unless you get it through the manufacturer.
Feb 04, 2011 | Gemini Sound Products Gemini CDJ203 CDJ203...
I ripped, just a little bit, the fret cloth on my Marshall JCM 900 cab. how do I fix it?
This may or may not help:http://speakers.lifetips.com/cat/61245/speaker-repair/index.html Also:http://www.simplyspeakers.com/11speakergrills.htm You may be able to sew it if you can obtain a curved needle. You can buy them where you buy sewing machines and supplies.
Oct 19, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Oct 12, 2009 | Yamaha Music
MTX Bon Musica 16" Viola Shoulder Rest Logo
Top MTX Music Experts
Vito Vacirca Jr.
Are you a MTX Music Expert? Answer questions, earn points and help others
