Question about Gateway FPD2485W Television
When i go to bed at night I always turn my monitor off (FPD2485W) by time i wake up because its been sitting I go to turn monitor on and the button turns blue but for a second and it goes back to purple as if its not on. it takes me about 9 tries to get it to work the right way. before it would just go to orange and say no power. If i shut monitor off for a couple hours when go to turn on works fine it is just when left off a long period of time.
    Top Expert:
  • Gateway Master
  • 40,339 Answers
The power supply could be failing.
Posted on Jun 24, 2017
SOURCE: Slow start
(I'm copying a guest's comment above. What Gateway told him does seem to work - although in my case, the monitor was slow to start when plugged directly into the wall, and it was immediately fixed when I plugged it back into a heavy duty power bar.)
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or a different wall outlet by removing any surge suppressors." I did that and it works. It might be a certain kind of power bar they do not like. It worked for me so try that and see if that helps.
Posted on Sep 17, 2008
  • 903 Answers
SOURCE: doesn't turn on power led flashing blue then light blue then off
Posted on Oct 25, 2008
  • 40 Answers
SOURCE: Gateway fpd2485w lcd shows video then cuts off
I'm pretty sure the inverter board is bad. you have to replace it if you can or you can let someone else do it. you should find some on ebay for about $80 (not too bad compared to the cost of the monitor: over $200). but its up to you. But first, you should find out if you are still under warranty. good luck. please rate!!
Posted on Dec 16, 2008
SOURCE: Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Posted on Jul 08, 2009
  • 11361 Answers
SOURCE: The monitor does not turn on but blue indicator on light is on
Look for bad caps:
Posted on Jan 04, 2010
How do you potty train a dog?
It is easy but very time consuming.Get a kennel.Keep the dog in the kennel at night.Take the dog outside every two hours and put it on the grass.When it does its thing praise it and give it a snack.When it goes in the house,if you see it say bad dog and take it to the grass.If you do not see it just clean it,they don`t realize there is a problem after the fact.Dogs live in the moment.Do not leave the dog in the kennel for more than four hours at night.This means at bed time put the dog in the kennel and 4 hours later wake up and take it outside.Be consistent,always.Praise the dog when it does right and give it a treat,scold it when it does bad.Be patient this takes time.
Jun 02, 2011 | Exercise & Fitness
Set alarm clock
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
EEverytime I log onto my monitor a box with
If your monitor has a button to activate the OSD (On Screen Display),
just push that button to "exit" from the OSD.
Or, after a minute, press the OSD button, to enter "setup".
You should be able to change the "time" from "about a minute" down to 2 or 3 seconds.
Nov 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway Monitor FPD2485W
posibly a burnt out CCFL light , more likely an overloaded or burnt out CCFL power supply
Oct 16, 2009 | Computers & Internet
Hi, how do I connect this monitor (Gateway FPD2485W) to my RG6 wire? I wanna watch TV on it. Thanks!
Use an RG6 adaptor to and install it to your RG6 wire. Then, plug it at the back of your monitor.
Sep 21, 2009 | Gateway FPD2485W Television
No signal with acer moniter
Check your power settings on your PC (Start Button ---> Settings ---> Control Panel ---> Power Options)
Under the "Power Schemes" tab you will find the dialogue "Turn off monitor:" and then your choice. The power option refers to the SIGNAL sent to the monitor, not the actual monitors power-source itelf (although some can control both). It will simply stop sending a signal to the monitor and "put it to sleep"
Change the setting to what is appropriate for your use, and you should be set!
Hope this helps!
-- RT
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
May 18, 2009 | Computers & Internet
It turns off, or goes to sleep. Won't wake up.
Hello there topothemorni,
Are you familiar with Windows' "Power Options" module, and that within it you can tweak all things related to power saving (e.g., system sleep, hibernate, and automatic MONITOR shut off)? More than likely you just need to make a visit there and make some desired adjustments.
[Control Panel > Power Options]
... OR ...
Start > Run > type "powercfg.cpl" (without quotes), then hit Enter.
Once there, you'll probably find most everything self-explanatory.
Also, it may be responding to configurations adjustable from within the monitor itself. Somewhere on the monitor there will be a OSD (On Screen Display / Setup) button of some type, where from there you'll be able to make whatever necessary tweaks. Refer to its documentation if you don't find it self-explanatory.
Good luck and please let me know if you have any further questions, and/or just to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!"
Mar 26, 2009 | Computers & Internet
Mar 22, 2008 | Gateway FPD2485W Television
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Gateway FPD2485W Television Logo
66 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
