Question about Cobra Electronics PC1000 Web Cam
I cannot get Skype to recognize my Cobra Camera. How do I connect this web cam to Skype
On web cam people can see me but I can't see them its saying not connected
it's not your CAMERA it works they see you, it's THEIR camera that isn't working. Have them go to Tools/Options/Video Settings and change it there. If they have a web cam connected to a laptop it's probably trying to use the laptop's built in camera, and if the lid is down you see squat. They'll likely have to go back and reset every time they reconnect the camera because Skype looses track of it and falls back to the default.
Aug 11, 2013 | Skype IM
Camera getting connected and then dis-connected and my photo is coming in negative
Skype is a free software program that allows you to make phone calls through the computer. It also lets you text chat and place video calls. Since Skype is designed for use with web cams, it has the capacity to take snapshots both of you and of the person to whom you are talking in a video call. Plug your web cam into your computer and make sure it is on, open Skype, click on the "Skype" menu, select "Change your picture," and then click "Take Video Snapshot." After that, you can decide whether you want to keep the picture or trash it. Use this option if you want a picture that people can see in Skype almost immediately and don't want to bother with downloading or uploading anything. b>
Jan 19, 2013 | Samsung 2012 Vg-stc2000 Original Skype Web...
We are trying to use a WiLIfe camera on a skype call but Skype does not recognize it. What are we doing wrong
Hi ,
1st you should be abale to have the web cam come on without being on skype, so you need to find the software that came with the web cam , if you dont have the software you can download it at www.logitech.com /support and type in make and model ...web cam and download the software it needs ...............if you have done this already , you can try deleteing skype software and then reinstall it ...............Im here to help , so please let me know if this does'nt work for you .......Goodluck ............................Roy
Aug 06, 2011 | Logitech WiLife Pro Webcam
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
Skype won't recognise my Logitech web cam. The
try to update your skype application...
i have read some article in the internet saying that in US they are experiencing server down....
skype is one of them.. maybe that is the reason you are experiencing problems in your peripherals...not your camera is the problem... the problem is in the net..
Feb 06, 2010 | Veo Mobile Connect Webcam
Skype does not recognize veo web cam
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Jun 06, 2009 | Veo Connect Webcam
Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Mar 12, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Quick cam chat to skype hookup?
Skype usually recognizes the web cam. If not try reinstalling Skype if your cam works
Feb 10, 2009 | Logitech QuickCam Express Web Camera
Aspire 7720-6155 wweb cam
it's likely a Skype setting. Try this in this exact order:
After turning on computer, insure that camera is connected ad recognized by computer,
Then start skype. In Skype: Choose Tools: Options, in the general tab (on the left) select video settings, click on "enable skype video" and "start my video automatically when I am in a call". Lastly under "select webcam:" click on the pull down menu and select your camera.
Save and you are ready to place your video call
Jan 11, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cobra Electronics PC1000 Web Cam Logo
102 people viewed this question
Top Cobra Computers & Internet Experts
richie46
ka4iup
ka4iup
Are you a Cobra Computer and Internet Expert? Answer questions, earn points and help others
