Question about Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum
Loss of suction on a canister bagless. What is the best way to ensure there are no blockages - i have checked but can't be sure there isnt a blockage in the hose somewhere.
  • 3,400 Answers
Take a coat hangar (one of those nasty metal ones) straighten it out as long as you can get it and slowly slide into hose, twisting it as you go. You can also tap hose when doing this to loosen anything jammed in there.
Posted on Jan 04, 2011
On the canister where up open from the top, is a round hole with a foam piece. When I vacuum is opens and losses suction and makes a weird noise. What is this piece and whats happening?
If you are referring to what almost looks like an exhaust, it is the bleed valve which is opening. The purpose is to ensure there is some airflow from somewhere when the machine has become blocked. This is usually accompanied by a whistle noise.
I would go through the checks in the following web pages and make sure that your filters have been washed frequently.
How to remove blockage from the wand and hose
How to remove blockage from the cleanerhead and brushbar
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
I hope this helps.
Many thanks,
Allan
Dec 09, 2015 | Dyson DC25 All Floors Bagless Upright...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
Loss of suction when pulling out the hose and then the hose sucks up tight. . . cleaned the filter under the canister. not sure how to do anything else. . .
I'm sorry to hear you've had difficulty with your DC14 Animal. It sounds as if there may be a blockage in the hose, wand or U-bend of your machine. To check for this, please follow the steps shown in our online Support guide:
http://content.dyson.com/support/help.asp?article=657&product=DC14-ANIMAL_US
Please note, the filter underneath the clear bin does not need maintainance - so if you've washed this, you may want to email us at askdysonUS@dyson.com for further assistance as the filter may have been damaged.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 29, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suction on my dc08 is very poor when turbine head is attached - no problem when not. I have cleaned the brushes an ensured there are no blockages. Why the loss of suction when using turbine head ?
please go to the web page www.dyson.com and go next
http://www.dyson.com/support/help.asp?article=1468&product=DC22-TURBINEHEAD-US
and fix it. with commong sense.
God bless you
Jul 19, 2012 | Dyson DC08 Cylinder Bagless Canister...
Seems like there is a decrease in suction?
Ensure that the canister is emptied thoroughly and that there is no blockage in vacuums path (Check for Kleenex's or in my case, cat toys)
Feb 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
It's lost suction even though we've cleaned the filters. Is there anything else we can clean?
Yes. Remove the hose, disconnect all the different sections and visually check for blockages. Make sure you check the cleaning head as well. If nothing is visible reassemble by adding ONE SECTION AT A TIME and check the suction by switching the power on and seeing if the hose will stay stuck to your hand when you turn it upside down. If you find that the suction dies after re-attaching a particular section, then there is a blockage in that section. Make sure you re-connect all sections of hose fully and correctly.
Try this and report back.
Oct 16, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Dyson power head stops when on carpets, cleaned brush out, still happens.
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Jan 31, 2010 | Dyson DC11 All Floors Bagless Canister...
Dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
Jan 31, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction
Check again for obstructions in the hose. Also underneath where the debri goes when it is being sucked up. Also make sure all your hoses are connected as this could effect the suction.
Nov 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum Logo
125 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
