Question about Gateway MT6705 Notebook
Internet problems wireless network adapter cannot find any wireless networks
  • Ed Deguzman
    Ed Deguzman May 11, 2010
    Were you able to find and connect to this wireless network before ? Are you trying to connect to your home wireless network and what type of wireless router do you have ? Is there any computer in your house that can connect through this router ?
    Did you make sure your wireless card is not disabled ?
  • 385 Answers
Connect PC to router with hardline data cable. open browser and type in 192.168.0.1 or perhaps 192.168.1.1 -- when the router displays it will ask for a password. if you had one and can't remember it do a hard reset to return to factory settings. then log into it leaving the username blank with the default factory password. many times that password is admin -- download the owner's manual that will have the default password and instructions and explanations for the settings, including how to do a "hard, factory" reset for free at the manufacturer's website. try the help, support, or download sections. the drivers are there too.
Posted on Sep 10, 2010
  • 31 Answers
Make sure ur W-lan is on .... should be on the bottom of pc... not bottom but that middle part right below the mouse .... if it isnt wait a few days and it might work....if it is... then u dont have any intenet connection
Posted on Jun 25, 2009
2 Suggested Answers
shynysaxena
  • 166 Answers
SOURCE: wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
Posted on May 28, 2009
Wireless assistant
hi, try to download win wireless driver on the p c
Jun 18, 2017 | ASUS Computers & Internet
Having a problem with my d-link DW 110 wireless adapter! cannot connect to internet or to my network!
have you got an IP address? how is your internet setup (wifi, Modem) if wifi have you put the correct SSID in. Can you see your SSID (name of your network)
Sep 01, 2011 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
I have 2 PC in local network via LAN. One of this PC1 use D-link DWL-G122 wireless g usb adapter connected to other wireless network. Can i get funcional internet on PC2, using this other wireless...
yes, from the network connections page right click on the network card that you use to connect to the internet. select properties. go to the advanced tab and enable network connection sharing. (it will say something similar to "share my internet connection with other computers on the network" varies slightly with diferent versions of windows)
Aug 18, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Netgear wg111 - I am connected to wireless network
i have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Jun 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Wireless internet
1. Go into the Network Connections (Start->Control Panel, Network Connections)
2. Locate your Wireless Adapter and make a RIGHT click on the icon.
3. Click on "View Wireless Networks"
If that does not work, it may mean that your wireless adapter is using a customized software to manage wireless networks. This is the case for my Intel Wireless adapter. In this case, look in Start->All programs for a program from your wireless adapter or laptop manufacturer (if the card is embeded). If you tell me the exact name of your wireless adapter, I should be able to help you a little further.
Apr 20, 2008 | Computers & Internet
Network Adapter
Based on your post/description:.
1. “I am able to connect to a wireless network but am not able to connect to the internet.”
Indicates that your wireless network adapter is working since "able to connect to a wireless network". The "not able to connect to the internet" may be settings/configurations.
2. “When the computer tries to self diagnose, it says there may be a problem with one or more of the computer's network adapters
Which can only be your wired network adapter (Ethernet) but since you are not using that but your WiFi, should not make any difference.
To simplify, let’s focus on the Internet connection. Pls verify/determine that:
a. the wireless network is connected to a modem and can access the Internet;
b. the brand/model/version of the wireless Access Point/Router and its IP address;
c. the wireless security method being used by the network (WEP, WPA, MAC filter); and
d. the IP settings given by the DHCP server (which is also the router) to your PC which includes IP Address, Subnet Mask, Default Gateway & DNS Servers.
Pls post back results of a, b, c, & d that we can figure out the solution for your concern.
In the meantime, you can try right clicking on your networking icon (bottom right side) and click on repair.
Good luck and kind regards.
Nov 13, 2007 | 10 10 Computer Network adapter Cable...
Gateway MT6705 Notebook Logo
138 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
