Question about Hoover Nextra HNL 3166 Z Front Load Washer
Hoover hnl662 starts up lets in water for 30 sec then stops . will pump out on spin.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Check the motherboard
is need to be replaced
Posted on Jan 04, 2011
The drum is not turning, but the water pump is working. The belt is OK but the motor that drives the belt does not seem to be rotating
Using a voltmeter check to see if electricity is reaching the motor - if it is then the motor is no good and in need of replacement.
If the motor has a start capacitor you can try replacing that first before replacing motor. If no cap, just get the motor.
Sep 09, 2015 | Hoover Washing Machines
My Neff dish washer runs for about 30 sec to a 1 min then just turns it self off the water pump sucks water in ok and the pump takes the water out ok ? help
that sounds like normal operation......the pump takes out remaining water then stops and lets in new hot water.
Oct 26, 2014 | Neff Dishwashers
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
HOOVER HNL662 80 I have just replaced washing machine pump as machine was not pumping out water. As machine still not working I cleaned drainage flexible pipe. As it is still not working would you please...
Make sure your pump is getting over 110VAC If the pump is getting power and turning there must be a kink or block in the hose from the washer to the drain.
May 02, 2011 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
How do I set the washing machine to spin only on a Hoover Nextra HNL662?
Adjust the timer to the end of any cycle. The pressure switch will recognize the water presence, and drain before spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2009 | Washing Machines
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Hoover Nextra HNL 3166 Z Front Load Washer Logo
184 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
