Question about LG Heating & Cooling
Lg out door unit shows a CH23 error.What could the problem be? Could this mean that the PC unit has gone. Thanks Joe
  • 2,133 Answers
Inverter dc voltage low. Check dc voltage of capacitors 300 Vdc for 1Ph and 600 Vdc for 3Ph. If OK change outdoor inverter PCB. Helpful?
Posted on Jan 04, 2011
LG LMV 1680 ST shows error AC-1 and will not heat. The turntable does not turn either. The exhaust fan still works and the control panel still responds. What does this code mean?
Check the fuse. Also check out the safety switch by the unit door. If not closed when door is closed, no power is applied to either the turntable or the tube.
Aug 22, 2017 | LG Microwave Ovens
My lg washing machine just make a beeep sound then show a error de
de error mean door error. For fixing this you can try to reset using the instruction from lg site (http://www.lg.com/us/support/product-help/CT00000305-20150140270078-others).
If not work, maybe de switch is bad or the door is not closing properly.
Jun 10, 2017 | LG Washing Machines
De error code lg washer?
This is a simple error it means the door switch( Door Error ) is not making showing an open door check nothing stopping door from closing if still a problem might need to diagnose door switch
Apr 17, 2016 | LG Washing Machines
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
DE error problem
Hello this is the link direct from LG if your unit is an LG on the DE error message http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799 sometimes you can get the error to clear by unplugging the unit for 7 minutes which causes the control to reset if it reappears then you would have to replace the door lock assembly in the unit. If you have any further questions message me back Thanks Rick
basicly means the door lock has not cleared in the home position usually it will reset by unplugging the 7 minutes
Aug 15, 2011 | Washing Machines
I have a LG WD - 1049C front loader washing machine showing the DE error have emptied out the washing machine and it still comes up, partner bought a new door latch and installed it but the DE is still...
DE error does mean the door latch,but there are three parts that could cause the error code.If you have changed the door lock already then the main p.c.b/computer board has failed and not registering the door lock but there is a 5-10% chance it's the wiring connecting the two parts together.So basically you need to change the main p.c.b & if that doesn't work it needs to be rewired.unless you know how to use a multi-meter then you could test the wiring for a definate answer.THANKS ECO KIZZA
Feb 18, 2011 | LG WD-1045FH Front Load Washer
What does code F DL code mean?
Hi
Thanks for using FixYa. Error FDL means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please do rate the solution if issue is resolved else post a comment for assistance.
Thanks
Rylee
Jul 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
577 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
