Hp cue staus root ha stopped working - Office Equipment & Supplies
5 Suggested Answers
SOURCE: HP Cue Status Root has
ça m'etonne plus que chez HP ils licencient un max , c est une réponse à la con et le mec y ferait mieux d"aller à la peche que de te repondre des conneries pareilles .
sous Vista.
methode rapides .
1 /Panneau de config
2 / outils administration
3/désactiver le service HPCUE
et voilà tu ne seras plus embeter parce truc de merde .
il doit avoir une autre solution pour virer définitivement ce probleme , on verra plus tard fais dejà ça et ton pc va demarrer normalement et plus vite .
Posted on Oct 24, 2008
SOURCE: HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Posted on Dec 15, 2008
  • 86 Answers
SOURCE: hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Jul 10, 2009
rulds2008
  • 3866 Answers
SOURCE: tengo problema con la impresora hp photosmart
debe a reinstalar el programa o arrcadora de HP. Si eso no fuciona debe a chekar si la foco de escanner esta fucionando correctemente. Ese problema es de arracdora/driver que llavar Hp. Debe a reinstalar de programa.
Gracias
Posted on Apr 22, 2010
My HP printer stopped working and is stuck in the cue
Navigate to Printers under the control panel and try deleting all current print jobs. Then also make sure to click on Printer> and see that the Work Offline option is NOT checked. Good luck
May 27, 2012 | HEWLETT-PACKARD Computers & Internet
Tengo problema con la impresora hp photosmart C5580 AL MOMENTO DE ESCANEAR SALE HP CUE-Scanning Flow Component ha detectado un problema y debe cerrarse.
Gracias
Apr 22, 2010 | HP Photosmart C4580 All-in-One InkJet...
Hp cue status root has stopped working
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
HP CUE-Scanning flow component has stopped working. a problem caused the program to stop working correctly.
good solution/workaround here
http://hpanswers.blogspot.com/2008/07/hp-cue-scanning-flow-component-has.html
May 21, 2009 | HP Office Equipment & Supplies
Error= hp cue status root must close system
hi,you can try restoring your computer to an earlier time,with the system tools located in the start menu.
Mar 04, 2009 | HP Pavilion dv6000z Notebook
"hp cue root status has stopped working" problem
This computer has OS preinstalled and a Recover CD (called RESTORE) supplied by the manufacturer.Insert this (black colored CD) let it ry to boot. Be patient and when prompted remove his CD and follow the instruction as it appears on the screen........sodeep
Mar 02, 2009 | HP Pavilion dv6000z Notebook
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
Aug 15, 2008 | Office Equipment & Supplies
216 people viewed this question
jasbo
jasbo
