Question about Garden
How to change battery in my motor - Garden
    Scholar:
  • 127 Answers
I need to know what you are trying to change the battery in. Please provide the make and model of the item and I'll try to help
Posted on Jan 04, 2011
How do I change the batteries in the Zhu zhu pets?
Changing the Batteries
A. Turn the pet over and unscrew the
motor box
B. Remove the motor box.
C. Replace the two AAA batteries matching the
polarity shown inside the battery compartment.
Be sure the batteries are firmly seated.
D. Replace the motor box and screw snug.
Jan 05, 2015 | Cars & Trucks
Boots blood pressure arm monitor not working-flashes on then off-i have changed batteries-what else could the problem be.
Check batteries.. Do not just change them. Locked motor will overload current draw.. See if you hear motor cycle when powering on.
Sep 30, 2014 | Health & Beauty
2006 pursuit g5 car won't start sounded like starting motor so changed it still doing same thing
Yes battery could be low enough to not be able to start the car but still work everything else
Mar 03, 2014 | Charging & Starting Systems for Pontiac...
Boat motor won't start. battery fully charged
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
Jul 07, 2012 | Nitro Boating
My piaggio fly 100 will not sart. I have checked and changed the battery. I have had the starter checked, it is fine. I have changed the starting pinion and still the problem persists. it is turning over...
You state that you have changed the battery but did you change it for a brand new one ? It appears your batteries don't have enough power to spin the motor fast enough to start the motor.
This could also be the reason it stares OK when hot, the battery having been given a fresh charge by the alternator, Try a new battery. your local dealer will probably agree with me.
Aug 16, 2017 | Motorcycles
Its a 1990 sportster and both the front and rear brake are not working i'm charging the battery and how hard is it to change the strator
To change the starter motor is easy. This describes the Hitachi Starter Motor removal and replacement. The Bendix type is similar but fatter.
Disconnect battery!
Remove the fat battery lead from the side if the motor and hold out of the way.
Remove the nut holding the chrome cover on the motor.
Undo the two threaded bolts that hold the motor on and remove the motor.
Re fitting is the reverse.
Remove the brake callipers as a unit and inspect for damage, corrosion and pad replacements.
Hope that helps.
Jan 13, 2011 | Harley Davidson XLH Sportster 883 Deluxe...
Blower motor runs for a few minutes then slows down then stops I have already changed out the resistor
change out the blower motor instructions below!
  • Disconnect the negative battery cable.
  • Disconnect the blower motor lead connector from the wiring harness connector.
  • Remove the blower motor cooling tube from the blower motor.
  • Remove the four retaining screws.
  • Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
  • Lift up on the blower and remove it from the blower housing.
  • Installation the new blower motor by reversing the removal steps.
  • Connect the negative battery cable.
  • Dec 22, 2010 | 2000 Chevrolet Malibu
    I have a 2003 jeep Liberty (freedom Edition). My blower motor doesn't work. it comes on sometimes intermittently. I tried changing the Blower motor resistor but that wasn't the problem. I changed the...
    most likely the blower motor it's self needs to be changed! Instructions below!
  • Dec 21, 2010 | 2003 Jeep Liberty
    Starting problem, changed battery,no power
    If battery changed "in" is known to be good then is either
    a) Fault on ignition key not sending power to starter motor when turned
    b) Faulty Starter motor
    c) Alarm/Imobiliser Active
    Check power lead to starter motor with test lamp. If when key turned wire to solenoid goes live, dismiss a) and c) which leaves b)
    If not live then either a) or c).......
    Jan 20, 2010 | 1995 Toyota Camry
    Intermatic outdoor can't reprogram. display reads NoOp
    Les, First thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers will fail, as some models have a known history of failing fairly often.
    NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
    You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
    Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
    Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
    Hope you find this Very Helpful and best regards!
    Sep 09, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
    Garden Logo
    12 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
