Question about Harman Kardon HK 3480 Receiver
Harman Kardon HK3480 with no display
I have a HK3480 with no display.
Unit comes on, power LED changes from red to blue, relay clicks, but no other lights come on.
Open SKy
  • 620 Answers
SOURCE: harman kardon
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Posted on Dec 30, 2007
  • 72 Answers
SOURCE: shutdown; red LED blinks 4x
The Error 4 is refering to a I2C4 communication error between SSB (small signal board), and the Logic board ( located underneath the SSB (under the bracket). Very high probability the SSB is bad. current replacement SSB 12nc is 313926809052
Posted on May 01, 2008
  • 1114 Answers
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Posted on Jul 01, 2009
  • 281 Answers
SOURCE: harman kardon audio system for harley davison not calibrated
You cant. Unit needs to be calibrated at the dealer with their digital tech or at Iron Cross Audio.
Posted on Aug 21, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
My Harman Kardon is AVR 151. It's not on. the power led is blinking. Sometimes it work correctly.i don't know what to do. please help!!!
Normally its a power supply that does that its protecting itself from further damage you will have to check the transformer or power supply in the unit normally it would be blown capacitor s
Sep 03, 2016 | Harmon Kardon Harman Kardon AVR1510...
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
Feb 09, 2016 | Audio Players & Recorders
Where to buy transistor for hk3480 part num 328 kca3114
Are you sure that is the part number? The HK-3480 uses a KTC3114A and is quite easy to find. Q317 and Q318 in your receiver.
Make sure you see the numbers correctly.
Jan 16, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
Hk3480 buzzing
Is the buzzing coming over the speakers or just from the receiver itself?
If over the speakers:
Try swapping ports on the receiver from the DVD. Go from DVD into an auxiliary video or VCR 2 if available.
Try swapping out the cables with known good ones.
But do this in steps to be able to nail down the problem and not just leave a mystery.
If the sound is solely coming from the receiver it could be a dusty fan. Blow it out with compressed air ,With the Power Off.
Or, my favorite, might just have to crank it up so you can't hear the buzzing.
good luck
Mar 11, 2008 | Harman Kardon HK 3480 Receiver
Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
May 01, 2007 | Harman Kardon HK 3480 Receiver
Harman Kardon HK 3480 Receiver Logo
77 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
