Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Syncmaster 204B
Alright my monitor is just showing a pale gray screen not really sure whats wrong. I've plugged it into my laptop an I've plugged it into my dell desktop it still doesn' t seem to be working.The pale gray screen is pretty current it flickers a tiny bit every once in awhile but not enough to mean anything. I've tried multiple monitor connections an multiple power cords still the same thing. Does anybody have any idea whats wrong?
  • mikeb0515 Jul 23, 2008
    My syncmaster 204 has been in constant use for 2 years, attached to a Dell desktop. Now when power on in the morning, sometimes get a grey screen, sometimes a grey screen that transitions to black, and then starts to flicker.
    Never does work properly, unless pull the power on the display wait a coupld of minutes and reattach power. Then after the flicker and black screen, within 2 minutes I get a good picture and everything works okay.
    Same issue when I come in the following morning. I do turn off the power switch on front of display before leaving every evening. Now I have taken to also pulling the plug.
    Any ideas would be really helpful. I have a colleague with a similar problem, except he cannot get his LCD to work at all.
  • Anonymous Apr 05, 2009
    followed the directions in the PDF file...violla! Thanks!!!
    Problem Solver:
  • 6 Answers
Try to replace C110 and C111 in the power supply circuit. These are 820uF caps and are in parallel. I had slow start and a flicker on this same monitor. Replacing the caps fixed it. Good luck, Ryan
Posted on Jan 06, 2009
  • Karakantouvalos Dec 08, 2011
    Mine is a 204T and the cure was exactly what cutman91 described above. Replacing the two 820 uf, 25V caps did the trick. Thurs., 08.DEC.2011
I've had at least 4 Samsung SyncMaster 204T monitors with flicker problems. Up till now Samsung has replace under warranty. But the new ones only last a year and then develop the same problem. n7qj's solution worked great for me. Thanks. While I performed n7qj's fix, I documented the process and created a .pdf set of instructions so others can benefit. I wish you the same success.
Posted on Mar 12, 2009
  • Bryan Mar 02, 2011
    When an associate left the company, he gave me his old monitor. And he even left me his 'dead' Sync 204B. Since I needed 2 monitors I took them both. There were a couple of snickers when I said that I would give it a shot at fixing it; better than the janitors throwing in the dumpster. Found this site and djonce instructions. Took mine apart and found the same 2 820uF and the 330uF were all 'vented'. Replaced them all with same uF but at 35V. Tested it before putting it back together and it is awesome!!! I can't wait to tell them it cost me more in shipping than the actual cost of the caps!!! And of course I will snicker as I say it.....
    I used Mouser.com
    820uF 647-UPM1V821MHD $1.71 each
    330uF 647-UPM1V331MHD6TO $0.21 each
    $3.63 for a new monitor!!!! snickering as I type this.....
    THANKS djonce. Awesome instructions.
  • Jensen Lum Sep 29, 2011
    Fix worked perfectly on my 204T (flickering on start-up). Thank you very much for spending the time to write it up. The only thing I can say is to not be impatient like I was, and not measure the capacitor size before ordering. I soldered them in a bit sideways just to make sure I didn't hit the top.
    Note: I used low ESR and 105C temp rated Panasonic "FC" caps.
Hi, this problem is the same with the 204B and the 204T. The 204T is the one described in the PDF. The 204B is the same circuit inside (slight difference in the connectors, but everything else the same). The only issue in the 204B is there is no place to "start" the separate of the front plastic from the back plastic. I just started with a Swiss Army Knife using the blade to carefully pry in the "crack" starting at the same place (bottom of the monitor). Just use the knife carefully and the front bezel will "pop" out fo the hooks on the back one, and you can remove the back cover and proceed exactly as the PDF indicates. I used 1000 and 680 uF 35V caps (they fit, and they give the circuit maybe some more tolerance). 204B and 204T worked like new (i repaired both). Great repair description! N3CKF
Posted on Jun 14, 2009
Hi, I just wanted to take a moment and thank n7qj and djonce for the solution to fixing my Samsung SyncMaster 204B monitor.
I saw djonce's reply last night, download his PDF (Thank You very much! With absolutely no previous soldering experience, your fantastic PDF instructions allowed this noob to breath new life into my secondary monitor... IT IS FIXED!!!).
Once I knew what was broken, I googled a bit, went to RadioShack which had both capacitors for $3.18. Including the soldering iron, solder, braided copper for un-soldering and all... this fix still cost me less than $20 for everything. Yes, I'm thrilled!
djonce, check the link to your PDF, right now, it's a 404... but I was able to find it thankfully ;).
Thanks again guys.
P.S. I'll register at this site just to be able to post my thanks.
Posted on Mar 21, 2009
  • Samsung Master
  • 1,684 Answers
Check our web site at www.ccl-la.com/badcaps.htm We have a free step by step dis-assembly and repair guide posted. The pictures and part number are available to help you get going. By the way there are several versions of the 204B / 204T power supply and our guide covers both.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Posted on Nov 12, 2009
just a few hours ago, I experienced similar problems with my SyncMaster 204Ts. Yesterday, it was working great and today the backlight refused to work. So when I powered it on, the screen remained black. After a few minutes of running, I could see very dim graphics. I then found this website and the linked PDF.
I did exactly what was described. Instead of two 820uF @ 25V I put in a 1000uF and a 680uF @ 25V, replaced the other three capacitors for convenience and it WORKS.
Thank you very much for your effort!
Regards
Maik
Posted on May 19, 2009
    New Friend:
I have a Samsung Syncmaster 204B that had slow start and flicker problems as well as being much dimmer than when it was new.
To n7qj and djonce..THANK YOU!
I brought my monitor to a tv repair guy and gave him the information posted here on the site and he replaced the capicitors and it works like new now and it cost me $75.00 total which is half the price of a new monitor.....I am happy.
Many Thanks,
Rick
Posted on Nov 04, 2009
    New Friend:
THANK YOU!
With the fix provided by n7qj, along with the well documented procedure djonce kindly provided, I was able to easily repair my 204T. Note that there was no 'flicker' involved in my case; there was a 'pop' and the panel went blank.
Upon disassembly, I noticed that c110/111 were clearly failed. one of them had actually pushed the rubber plug all of the way out of the bottom of the can and let out the magic black smoke that makes these things work :-)~
I noticed that all the electrolytic caps on the circuit board were from the same manufacturer. Most showed suspicious signs of bulging, so I went ahead and replaced them all. ~$12.00 from Digi-Key, including spares and shipping. Problem solved. I think I paid close to $500 for this thing when new, so NOT BAD.
cmiller6259
BSEET, DeVry Institute of Technology, 1994
Posted on Nov 01, 2009
SOURCE:
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
When my Syncmaster 204B (used as Monitor #2-1600x1200 60 hz) goes to sleep I can't get it back on. Power off/on, replug etc. every now and then it comes back. What's up?
Sounds like the powersupply is faulty. If it used to work for a moment then the picture dissapeared, and then if you turned it off and back on, the picture returned for a moment.
That would indicate a power supply issue, in that case it would definitely be a bad electrolyte capacitor or two. In your case I'm not sure but its either the power board or then there is something more complex wrong on the smaller mainboard inside the lcd back cover.
Sep 21, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B - when pc goes into blank screen mode (normal) the monitor does go black (normal). But when waking up PC the monitor just start flashing the screen extremely fast, progressing slower and...
Yes, The repair is simple, it requires changing out 5 capacitors. We have a full repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ We also have a parts kit available for $12 shipped.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor flickers and turns off. samsung syncmaster 204B.
this is very frecuent in all monitors or tv's lcd .... turn on 3 seconds and off the capacitors need to be replaced y sugest a technician
Sep 16, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
9,202 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
